Question about Panasonic DMP-BD30K Blu-Ray Player
Panasonic DMP-BD30 won't read blu-ray disks
This unit is one year old, was stored in a closet for 11 months after being used one month (divorce situation). Worked beautifully for that month. Plugged it in to the same video setup I had before in my new apartment, and now refuses to play any blu-ray disk (says "NoREAD", then "STOP"). It does play regular DVDs...what a waste.
I'm guessing from the way its acting that it's out of warranty. Really angers me that for so little use I've got to pay someone to fix what is obviously Panasonic's problem. Any suggestions? Anything I can do other than drop a couple hundred bucks fixing or replacing this boat anchor?My experience is similar. What I have found is that the DMP-BD30 will play a brand new out of box disc on the second or third try. However, it will not play 9 out of 10 NetFlix discs. What is really puzzling is that it will sometimes play a particular disc through a couple of episodes and then on restart will simply not load.
A Panasonic serviceperson told me that NetFlix' floppy envelope is not enough protection for the brittle Blu-Ray coating and that their packaging approach causes microscopic damage to the discs and that's why they won't play.
I have turned off my Blu-Ray preference at NetFlix because of the hassle, but what a waste. Net Flix says there is nothing wrong with their discs, the envelope works fine and that the player is the problem.
Who should I believe?
  • Len DeBenedictis Feb 16, 2009
    I bought a cleaning disc and cleaned the player. The problem remains.
    I loaded a brand new Blu-ray disc and it took about 10 tries to get it to load. I noticed that the time that on the try that worked I allowed only seconds between ejecting the disc and reloading it. I don't know if that was coincidental or meaningful; but obviously something is wrong with the player.
    Use of a cleaning disc did not help in my case. The problem persists.
    I loaded a brand new Blu-ray disc and it would not read. I tried reloading about ten times and it finally loaded, after which it worked perfectly. I noticed that the time that it did load I had allowed almost no time to pass between ejecting the disc and reloading it. I don't know if that was a coincidence or has some signficance in terms of what is wrong with the player. Obviously, something is wrong with the player.
  • 126 Answers
Your DVD PLAYER'S lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD PLAYER clean the dust in it & it will start working again but be careful remember that no power should be attached to PLAYER.
or you can buy a lens cleaner from market and try that.
pls rate me
thankyou
Posted on Feb 14, 2009
  • vishal garg
    vishal garg Feb 15, 2009
    i will prefer you to clean DVD PLAYER from inside
  • 679 Answers
Clean the player using a disk cleaner, and check again.
  • Panasonic Master
  • 19,396 Answers
The most likely is that the lens has duston it, try first cleaning the lens.
DMP-BD60K Blu-ray won't read any disc after firmware update
Check with Panasonic---this is the risk you take when trying a update especially if the unit has no real problem......
Oct 16, 2012 | Panasonic DMP-BD60K Blu-ray/DVD Player
Upgrade BD30 wi-fi
To upgrade the firmware you will need to download the newest firmware from this site: http://panasonic.jp/support/global/cs/bd/download/bd30/index.html and burn it onto a cd. If you can't or don't want to burn the cd it looks like they will can send a copy of it to you.
Mar 02, 2012 | Panasonic DMP-BD30K Blu-Ray Player
My Panasonic DMP-BD655 won't read any discs. I was fine a month ago but hen it wouldn't read Blu-Ray discs, but would still play DVD's. It stopped playing DVD's about 3 days ago. I have upgraded the...
Ive only had mine for 2 months and it just stopped playing dvds all together. I had a brand new dvd playing, went to switch it to another new dvd movie and it wouldnt read it or any other dvd Ive tried. I havent tried a blu ray disc yet.
Jan 02, 2011 | Panasonic DMP-BD30K Blu-Ray Player
BD30 makes a grinding sound when loading discs,
in most cases its a bad disc but if all disc are doing it then your glide tray needs to be re alined
Jul 04, 2010 | Panasonic DMP-BD30K Blu-Ray Player
For a blu-ray player model #DMP-BD30, how do we get updates
goto http://panasonic.jp/support/global/cs/bd/download/bd30/index.html
download this and put it on cd-r using a program like nero or whatever burning software your computer came with, then put the disc in the blu ray player, turn it off then back on and make sure it doesn't get interuppted
Sep 08, 2009 | Panasonic DMP-BD30K Blu-Ray Player
Sounds like the DVD/Blue ray laser has gotten dust on it from being stored in a closet.
I would go to your local electronics store and purchase a cleaning disk. They are normally under $10. Insert it and run it though the player.
This sound no more serious than a dirty read laser.
Give cleaning a try.
Jan 29, 2009 | Panasonic DMP-BD30K Blu-Ray Player
Panasonic blu ray player ?
Hi , i just purchased a blue ray dmp bd30. i wish to use it as to play cds. It is connected to my 2 channel amplifier from the audio outlets, it is connected through the HDMI connection to a Pioneer PDP-428XDA. is it possible to play cds with the plasma turned off? I have folowed the instructions which describes turning off power from the options menu, but the options menu doest display?
Jul 01, 2008 | Panasonic DMP-BD30K Blu-Ray Player
Panasonic DMP-BD30K Blu-Ray Player Logo
350 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
