Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
DC07 brush wont spin on bottom, took all apart and wont work
The only thing that works is the wand, and we took it all apart and put it back together. The bottom brush wont spin and nothing is being sucked up. Any ideas?
  • 134 Answers
Hi
the belt is broken or stretched, replace it
Posted on Feb 14, 2009
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Little suction at all through the bottom sweeper but the hose is powerfull still..took apart,,spent real time,,new filter and all..still no luck. please advise.
Is the brush/roller spinning? If not, then the connection between the roller is broken, it is a two piece roller connected by a round black piece. there is a gear under there that can break and keep the roller from spinning together.
Mar 04, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brushes are not working.
We have a Max Extract 60 and when we turned it on the brushes did not work. My husband took the pieces for the brush motor apart and put it back together and then they worked fine. They must of been bound up or put together wrong. Works great now.
Dec 21, 2010 | Hoover F6055-900 SteamVac Maxextract LS...
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
My dyson DC07 has no suction. motor runs, brush spins, just no suction.
hi..the reason to this problem may be the bottom pieces
might not have been fully seated.Take it apart and put it
carefully back together.This will solve the issue.
check it out..
thank u..
kindly rate my response..
Jun 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction
Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
Remove hair from brush roll using scissors.
Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
If its stiff to rotate you will need new roller.
Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
Now check the long flexi hose & metal wand for any obstructions.
If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
Chris...
Sep 24, 2008 | Dyson DC07 All Floors Bagless Upright...
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
Roller brush won't spin (bissel 6390/3910 series)
I just fixed mine. It took me all of 10 minutes. Pull the brush out. Stand the brush on end on the edge of your study work bench/table top. while holding the brush vertical( on end) take a small phillips screwdriver and tap using a hammer on the metal pin you see in the middle of the brush. Keep tamping and the whole assembly will come apart. What you will have then is a long metal shaft, 2 bearings(they are acutally skateboard wheel bearings same number same make). Clean the gobbed up hair with a razor blade and then reassemble by tapping back together. The bearing wont be worn out because they are way too tough for a vaccum. We used ride down hills on them! a ten minute fix wow and you wont have to drive to vacuum shop and spend $$ and time
Dec 31, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
392 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
