Question about ACE Dimplex (r) Compact Electric Fireplace (DFP36430) Heater
Heater turns on and clicks right off no fan
Turn heater on it glows for bout 2 seconds and then clicks off and i hear no fan is ther ea fuse or something? model number cfp36850
Take unit apart and thoroughly clean ( vaccum out) the fan area. if it is dirty you should blow out accumulated dust from the same area, if the fan does not turn freely the unit will overheat and shut down
Posted on Nov 13, 2010
If no fuse on the outside of the heater then the fan on the inside of the heater prob died need new fan
Posted on Feb 14, 2009
Ignition is locked out unit will not fire
Turn it off at the black toggle switch inside the front panel or turn it off at the breaker for 2-3 minutes
Then try again.
Check that flow is good, gas is on ect...
Is it saying lockout on the display?
If not then as you fire it up after cutting power keep the panel off and watch the ignition control red diagnostic light.
The blinking sequence of that light should point you in the right direction. There is typically a label that will tell you what the blinks mean.
Minimax nt heaters are on borrowed time, and in most my Delong with them once they start having an issue it will never end , basically they are lemons and replacements for them is very common
Mar 28, 2015 | Pentair Minimax NT Heater
York furnace won't ignite
Is the igniter receiving 120 volts after the pressure switch closes? If not, either the board is bad or the pressure switch is open
Nov 27, 2012 | Heating & Cooling
Why will AC & Heater fan not turn on?
motor could be bad or something fell down defrost and locked up the fan.
Jan 29, 2012 | 2004 GMC Yukon
I have a Maytag performa. It would not run at all. I checked the thermal fuse and found it to be kicked. I replace it as well as the hi limit. I put it back together, it runs now but it does not get...
You will need to replace the "gas valve coils" on the dryer. If you will post your model number, I can direct you to the parts you need.
Jan 14, 2011 | Dryers
Both fans turn on but no igniter or heat ?
If the igmitor doesnt glow it is probably cracked. If it
is a spark ignition or in both cases check for a flame rollout switch located ontop of the burners should
have a little reset button.
Next if that is tripped yhou need to find out why, vent
plugged or another source drawing air away from unit
Jan 20, 2010 | Star Enerco Heat HSU45 Garage Heater 45000...
Glow plug light not coming on, on dash. Engine turning over but not starting. Have never had any trouble starting before. The fan belt has been screeching for about 30 seconds for the last few weeks when...
Check fuses to see if there are busted ones. Then check heater plugs if good. Heater relay included in check. Engine wont fire if the air inside the chamber is cold. Then check fan belts for wear, replace if necessary.
Nov 29, 2009 | Volkswagen Golf Cars & Trucks
REDDY HEATER 125T WON'T INGNITE
  1. Does the ignitor glow for 5 seconds when the unit is started?
  2. What is the air pump pressure reading?
These are the starting points for troubleshooting a heater that has an ingntor.
Answer these questions and maybe someone can get you started.
Dec 16, 2008 | Desa International RH125AT Utility Heater
Won't srtart
Check at the gas valve to see if you are getting power to the terminals after you hear the click shortly before the ignitor stops. If no voltage ...replace the board.
Sequence is
induction fan on, if pressure switch is reading ok condition---->
Ignitor is powered for up to 20 seconds (depends on model) ----->
Gas valve is energized ----> if flame is present everything just works away, if no flame in 3 seconds sequence starts over for set number of tries or continuously (again depending on the model)
Hope this helps
if 23/27 volts is present at gas valve then replace valve but bad valve is not very common usually, its the board.
Nov 08, 2008 | Goodman GDS80703ANA Open Flame Mid-Size...
Goodman furnace
Check the roll out switch(s) and the lock out switches. They are a small disc looking about the size of a nickle, with with 2 wires attached on them. There will be a re-set button in the middle that resembles a small peg. Push this in to re-set. As the glow coil shorted out, the fuse on the control board may have blown. On the newer furnaces find the main board and look for a car type fuse. If blown, replace. You also have the symptoms of a bad limit switch, by the clicking noise (the heat fan relay) and the blower fan running instantlly.
Jan 05, 2008 | Heating & Cooling
Heating & Cooling Logo
675 people viewed this question
Top ACE Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
Tim Whalen
Mack Baxter
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
