Question about ATI RADEON 7000 PCI Graphic Card
Unable to enable TV out function for his ati radion 7000 pci card
There is no ATI tab in display-settings-advanced as stated by manual to get to the TV-out enable. Is there another way?
  • Louie  Role
    Louie Role May 11, 2010
    Hi and welcome to FixYa,
    Have you tried plugging in the TV connector to the ATI video card and to the TV prior to booting? If not ,pls try and post back results if TV-out could now be enabled.
    Post back results. Good luck and thank you for using FixYa.
    Brigadier General:
  • 6,966 Answers
Posted on Feb 16, 2009
Solution for aspire 4745g when installing for ati driver it turn black?
An ATI adapter is a type of video adapter that is designed to be used on computers running Windows. If the adapter is disabled, you will not be able to connect any external monitors, video projectors or other similar devices to it, as your operating system won't be able to recognize it. Of the different ways you can enable this type of display adapter, one is through the "Display" manager in the Control Panel.
Click "Start." Click "Control Panel." Click "Display." Click "Change Display Settings." Click "Advanced Settings." Click the "Adapter" tab. Select the ATI adapter from the list on screen. Click "Properties." Click the "Driver" tab. Click "Enable" to enable the ATI adapter through the "Display" manager.
Or the driver you are installing is not compatible with your operating system or your computers hardware
Hope it helps
Jan 23, 2013 | Acer Aspire 5602WLMI Notebook
Radeon hd2400pro graphics...... the image on the monitor is flipped upside down and i cant get it back to normal
Right click desktop and select Properties to open up your Display Properties. Go to Settings tab and click the Advanced button. On my laptop that is using ATI driver, there is a Rotation tab. It could be Rotate tab as well.
If there is no option like present, apply this registry modification to enable it:
http://www.deltadevelopment.de/users/christoph/ati-rotate/
Apr 02, 2011 | ATI RADEON HD 2400 PRO Graphic Card
I need the drive of video for Windows 7, my drive is ATI_100705R
ATI RADEON 7000 GRAPHIC SUPPORT WINDOWS 7..
it supports xp 32-bit , windows 2000
if you want to install win 7 try the HD series of ATI RADEON.. HD series of ATI SUPPORTS WIN 7.
Dec 18, 2010 | ATI RADEON 7000 PCI Graphic Card
I don't have ati radeon 7000 graphic driver
go through the link below download the drivers and install it..
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/6-11-pre-r300_xp-2k_dd_ccc_wdm_38185.exe
Dec 16, 2010 | ATI RADEON 7000 PCI Graphic Card
Ati 7000 m6d64x20jy
you can download the ATI RADEON 7000 PCI Graphic Card driver from the link provided below
Dec 08, 2010 | ATI RADEON 7000 PCI Graphic Card
For my mac g4 first generation, i bought a Ati radeon 7000 PCI. the goal was to stop using my original graphics card and use the ATI radeon 7000 for my main and only screen but when i start up with my...
hello...the way is try to open the Bios Settings then disable the on board video then set primary AGP/PCIE slot Video Card to run then try again to install the video card driver but 1st you need uninstall the old driver..thanks and Good Luck..have a nice day..^_^
May 12, 2009 | IXMicro ix3D Dual Monitor (8 MB) Graphic...
SIS 315, 256-BIT AGP 4X VGA CARD VS GREEN ATI 7000 SERIES CARD
The ATI 7000 graphics cards are much better than the SIS 315 ones.
Apr 12, 2009 | ATI RADEON 7000 PCI Graphic Card
Require ati 7000 64 m pci vga card drivers
http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html
There is the divers if u running XP as OS, if not change the OS to that one you run
Im not sure that the issue is the 7000, it can also be your memory.
How mutch memory do you have in your pc?
Upgrade the momory solve a lot of problems whit gaming.
Good luck
Dec 11, 2008 | ATI RADEON 7000 PCI Graphic Card
Ati display card with network card built in
http://ati.amd.com/support/driver.html here you can download ATI drivers for your OS and Card, it's as easy as that.
May 21, 2008 | ATI RADEON 7000 PCI Graphic Card
ATI RADEON 7000 PCI Graphic Card Logo
126 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
