Question about Sony KP-65WS500 65" Rear Projection Television
String Art 2
Sorry posted this to the wrong location before. I have 5 Year old KP65WS500. The best way to describe the issue is that there is horizontal string art at the top third of the picture. There is a picture although the quality is poor. There are Red, Green and blue colors visable. Any ideas?
  • jnkfiles33 Feb 14, 2009
    Thank You
    Not a Repair Tech just looking to keep repair costs under control.
    Am now trying to figure out what an IC is.
    Thanks Again
    So it would appear that the repairs should run aprox.
    Service Call $109.00 (Quoted from Tech)
    Parts $ 62.00 ($31.00 x 2)
    Aprox $ 171.00
    Allow some upside movement for tax and such and it looks like around a $200.00 repair and not a $500.00 repair.
  • 10,594 Answers
It is failure of convergence out ICs and subject part needs to be replaced, TV has 2 ICs and both will be replaced.
If you are tech person or know TV repair, let me know to provide you more info or call local TV tech to fix it.
Posted on Feb 14, 2009
  • Shahid Electronics
    Shahid Electronics Feb 14, 2009
    Let me explain it..
    Click THIS to have a look of the IC what TV requires, quantity 02 (requires good soldering skills and enough electronics repair knowledge to replace ICs)
    I think its correct calculation and TV worth to be repaired.
    How about 4 blue diamonds rating of this solution?
How change strings gibson guitar?
One of the best was to keeping your guitar in tune, is to also string it correctly and use new strings . Make sure the first winding of a new string around the tuner post goes over the exposed tip of the new string. The rest of the windings go under the exposed tip of the string. This will keep the string clamped firmly in place. Use 4-5 turns around the post for unwound strings, 2-3 for wound strings, in a downward spiral towards the bottom of the post as shown in the photo.-Tom, 30yr player.
Apr 15, 2016 | Gibson Les Paul Studio Electric Guitar
What issues are caused if you have to much oil in a 94 oldsmobile cutlass supreme
generally high oil level will cause oil leak /oil burning issues
best to reduce the level to normal asap
problems you describe sounds like issues you might get on any 20 year old car that needs maintenance.
Oct 15, 2014 | Vehicle Parts & Accessories
How to determine if I have a Battery issue or a Charging issue with a 2003 H-D FXDXT? What should the Voltage of a "fully charged" 2 year old OEM H-D Battery be. I have a reading of 12.4/5 Volts. At a
Post by the "Owner". The "Fix" was a New Stator. (Broken Wire).
After recharging the 2.5 year old AGM battery 3 times with acceptable results each time. (13+ volts & 14.5+ Volts at high idle) Purchasing a new AGM Battery, a month & a half of "pulling my hair out, all the "great solutions posted on fixya", being stranded 3 times with a "dead battery", I took the Bike to the Shop/Trained Mechanic. Many Thanks to the Post concerning the broken copper wire & "fixya.com" for allowing me to Post. Thank You all.....
May 22, 2014 | 2003 Harley Davidson FXDXT Dyna Super...
Alternator will not charge battery
no year, no joy, sorry !!!!
so here is a generic answer....
1: alternator not reaching full speed. RPM. i use and optical tacho
or just set belt tension to spec.
2: fuses blown to alt, see engine bay fuse box.
3: wires fell off the alternator.
4: dash charge lamp burned out.
5: bad alternator.
6: some years the ECU regulates the Alternator.
old post
Aug 16, 2013 | Honda Pilot Cars & Trucks
The brush mount on my DC24 multi room is snapped and falling apart. i have searched online and the best so far is to get a new cleaner head at about 70 pounds. If I do this how do I replace the old for...
I'm sorry to hear you're having difficulties with your DC24. As long as the cleaner has been used in accordance with the terms and conditions described in the user guide, we should be able to replace the cleaner head for you under our 5-year warranty.
Alternatively, you can purchase a replacement cleaner head directly from us via our online store.
Please get in touch with us directly so we can help you resolve this issue - you can call us free on 0800 298 0298. Our Helpline is open from 7am until 10pm - we'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 21, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Removed 2 bolts what else is holding it. abracket dont know what else to remove to get to it.
Well Im no psychic but I could guess that "it" could be anything from a radio to a spare tire? You need to be more informative when describing your issue if you want assistance. Words like it and them and the whatchmacallit are too vague. Post your question with some details like Make, Model ,Year, Motor size, auto,manual, what you are trying to repair or remove. Sorry "it" doesnt help.
Mar 24, 2010 | 1993 Pontiac Grand Am
Please describe your issue or question (*) Last year we bought four of the Gemmy Color Chasing Light Show strings with the multi-color LED tear-drop shaped bulbs (#0293751). All four strings worked...
tombonw, I noticed this problem last year also, did the same string replacement as you, but by seasons end the new strings I bought had the same problem with a few doing something different. Did you ever find a good solution or hear from anyone else?
Dec 07, 2009 | Gemmy Toys
Sony KP-65WS500 65" Rear Projection Television Logo
195 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
