Question about Jenn-Air JGW8130DD Gas Single Oven
What is part #
Need to replace the electronics panel in JGW8130ADB oven
  • Anonymous Mar 08, 2009
    where do I find the oven ignitor in a single unit gas model???
    Novelist:
  • 117 Answers
Part number for the electronic control panel for your unit is 74008131 and cost is about 160.00 in new. If I can help further, I am here....
Waiting to hear from you,
Eric Campion
Posted on Feb 14, 2009
I have a Jen air gas stove . the oven isn't heating properly. the broiler works but the bottom will not heat on to 115degrees any solution?
Posted on Aug 23, 2009
My GE JKP45 double oven needs a new control panel (part # WB27K5047 which is no longer available) There are a few place I've found on-line that refurbish electronic panels, or if it only has a loose...
according to the website i use to look up part#s while the part# you have is indeed not available a replacement for it is WB27T10050
to removeand replace it unscrew the screws that hold it to the cabinet pull it out about 4-6 inches,remove the grill directly under the control panel on the upper oven and look for screws around the panel where ya have pulled it out of the cabinet
to see yourself the replacement part# go to searspartsdirect and enter the model# and you will see the eoc (electronic oven control) as item #16 under the control panel and top tab
Jul 20, 2011 | GE JKP45 Electric Double Oven
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Electronic control panel black out
it may have back lite lcd display and the lights have blown shine a torch into the lcd if you can read it then you need the backing lights replaced
Apr 21, 2010 | Whirlpool RBD305PD Electric Double Oven
Error f7 oven wont turn off
Hello there:
The f-7 error code carries several different possiabities
here are several possiable reasons and the things to check
1. F5 or F6 or F7 EOC (Electronic Oven Control) failure Replace EOC(Electronic Oven Control)
2.
F7 Shorted touch panel Replace glass panel
3.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace clock assembly (also called the ERC)
Please test each of these carefully ok and if you disconnect the board you may want toclean the contacts really good and then try to reconnect the wires and make sure that they are properly connected ok
Best regards Michael
Jan 12, 2010 | Ovens
Need to replace electronics panel; where can I get
Try an appliance shop in your neighborhood if they don't have it they can probably order for you.
Dec 16, 2009 | GE Profile JTP56 Electric Double Oven
F7 Error on GE Profile electric oven. No response from keypad.
The F7 error code on your oven indicates the touch pad has failed. To repair it, you will need to replace the touch pad which is listed as a control panel.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that holds the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touch pad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
Hope this helps.
Thanks for using Fixya.
Dec 15, 2009 | GE Ovens
Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Nov 05, 2008 | Whirlpool RBD305PD Electric Double Oven
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Oct 28, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
GE wall oven display say F7, Bake and alarm sounds
F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
Aug 06, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
Jenn-Air JGW8130DD Gas Single Oven Logo
215 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
