Question about Dell Dimension 5100 (D51L1) PC Desktop
Changing the BIOS
I need to change the BIOS to read CD Rom so I can run a scrubber program. I have a DELL Dimension 8200. Can you tell me how to change this.
  • Peter Steiert
    Peter Steiert May 11, 2010
    You will need to find out what type of motherboard your system holds. Then go to the manufacturer's website (of the motherboard, not the computer) and find the latest BIOS for your motherboard's version.
  • 395 Answers
To boot the computer from the cd
Turn off the computer and then turn the computer on
again.
3 When the blue Dell logo appears, press <F12> immediately.
If you wait too long and the operating system logo appears, continue to
wait until you see the Microsoft Windows desktop. Then shut down
the computer and try again.
4 Use the arrow keys to select the CD-ROM option, and then press
<Enter>.
Posted on Feb 14, 2009
How do I run a set up program
Generally, one enters the BIOS Setup screen by pressing either F2 or Del. There is usually a message on the bottom of the first boot screen that indicates what button is correct for that model.
Looking further into the details that you have given, it seems that your CMOS battery has died, so you will need to replace that. (This is what is causing the "Time of Day Not Set" message most likely.) You can get the appropriate battery at Radio Shack (if nowhere else) for about $5 or $6.
Oct 17, 2014 | Dell Dimension 3000 PC Desktop
No disc boot
Please test your media (DVD or CD? + or -? RW or R? I prefer to use CD-R) in other computer. Probably your T600e can not read the media. Did you make bootable disc? Please recheck it.
Dec 18, 2013 | Dell Desk Top Computer--and Lcd Monitor 17...
Dell Dimension 8200 PC Desktop Cd rom not reading disk
optical drive troubleshooting is pretty straight forward, fist see if you can boot to the drive using a bootable CD like the Windows CD or your Dell Resource CD, use the F12 1 time boot menu test it.
Also see if the drive is detected by model in the BIOS (F2 at boot) if not seen, reseat both power and data cables, boot to BIOS F2, turn on CAP LOCK SCROLL LOCK, NUMLOCK, then press ALT+E then ALT+F then ALT+B, this resets bios defaults and forces hardware re-detection. If you have no floppy diskette drive, you'll need to turn that back off in the BIOS before the ALT+B
If all that is done and the drive isn't seen/cannot boot to with bootable media, swap the data cable with the HDD and try a different power connection.
If Drive still not connected, replaced the drive.
If drive is detected and IDd then try this
http://www.fixya.com/support/r6169039-cd_dvd_drive_disappears_in_windows
Jan 28, 2011 | Dell Dimension 8200 PC Desktop
I have a dell dimension 3000 desktop. I removed a cd rom drive and replaced it with a audigy sound blaster front panel drive. when I boot my PC it says primary drive not found, press F1 to continue, Press...
Your computer is configured to recognize specific devices in your computer. If you removed the CDROM drive, you need to tell your computer that it's gone, and that you're aware of it. That message is kind of like a "Hey, there's something missing from your computer... did you know about this?"
You should boot your computer up and get into the BIOS. When your computer turns on, you'll see a message in the corner that says something like "Press F2 for BIOS" or something like that. Get into the BIOS menu using this option. When you get into the BIOS, you'll need to find the sub-menu called "IDE Devices" or something referring to IDE drives. You should see two IDE channels, with two possible devices per channel. You should see the entry where your CDROM drive used to be - change this option to "Disabled" and then save your settings and reboot the computer. The message should go away. Good luck!
Mar 08, 2010 | Dell Dimension 3000 PC Desktop
Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
May 28, 2009 | Dell Dimension 8300 PC Desktop
Reinstallation CD will not run
When trying to boot from a CD on a Dell system you should put the CD in the CD-ROM tray and reboot the computer. When the initial Dell splash screen appears, you should press F12 (not F2 for BIOS) for a boot menu. In that menu you want to choose the CD-ROM drive. If you have made changes in BIOS you may want to undo them and try this way instead.
Mar 15, 2009 | Dell Computers & Internet
Dell Dimension 8200 Processor
hi, i also hav a dimensions 8200 which i recently uprgaded to a 2.8gh, but i discovered there were two versions of this system one which supports a 400FSB and the other 533FSB, these can determine the speed of ur cpu. Like you, I havent been able to unlock my clock speeds in the bios but i think you should be able to get more from ur new cpu by updating ur bios version to A09. check the dell site for more info on how to do this.
Apr 25, 2008 | Dell Dimension 8200 PC Desktop
CD ROM
1.Try updating your firmware by contacting Dell technical support.
2.Try Calling a Local Technician To check for loose connection or Check it your self.
3.Reset your BIOS Settiongs
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Mar 28, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
75 people viewed this question
Alun Cox
