Question about Kenmore Washing Machines
Washing machine agitation problem?
I have a kenmore washing machine model 110.92291800. I want to know if the agitator should agitate on the bottom half and the top half does not turn hardly at all? Is it broken or was it designed to be this way ? If I hold down on the top of the agitator while in the washing cycle the top half will agitate -even if I pull up on it while agitating then it agitates somewhat!??? Is it supposed to do this?
  • 15,935 Answers
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Hi, I have a Kenmore Washer Model:110.24722300 70 Series. The agitator is slipping how can i fix this problem and what parts do I need.
Agitator Repair Kit
Item #2744 (OEM Part)
$19.85
Washing machine agitator repair kit with a medium length cam (there are other kits available for different models). This kit should be used when the top part of the agitator is not moving properly but the bottom part is.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285811/2744?modelNumber=110.24722300
Oct 19, 2012 | Kenmore 22422 Top Load Washer
How remove agitator cup to replace dogears on a kenmore elite washing machine
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Feb 12, 2011 | Kenmore Washing Machines
I have a Kenmore 110. (full number is 110-82984810) It has a "ratchet/screw" type agitator. The big fins on the bottom part agitate back and forth, but the center piece no longer moves in a...
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082984810/0582/0153200?pathTaken=
For future reference you might also want to review / print / save the following Whirl[pool / Kenmore Service Manual for these washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Dec 26, 2010 | Kenmore Washing Machines
How do you change the agitator parts on a kenmore model 20702990 top loading machine with direct drive?
Remove agitator by taking fabric dispenser off and removing cover down below, pulls up with not much effort. Remove 7/16 bolt and take out agitator from tub area. Stand on the bottom part of agitator and pull directly up holding on to the auger section. Sometimes takes some muscle but will come apart. Agitator dogs will need to be replaced. Part # 80040 from Whirlpool.
May 18, 2010 | Kenmore Washing Machines
I have a kenmore elite model # 20949 and the bottom of the agitator turns but not the top
direction only.
Oct 31, 2009 | Kenmore Washing Machines
Agitator does not work in Kenmore model
the agitator dogs are likely broken/stripped.
Aug 10, 2009 | Kenmore Washing Machines
Washer does spin but barely agitates
It sounds like the agitator dogs are worn.
To remove the agitator, pry off the agitator cap and remove the bolt that holds down the agitator. With the bolt out pull up on the top section of the agitator (auger) to remove it. Underneath the auger you should see 4 small white or beige plastic gears (dogs). . Replace those and it should be ok.
The part number is 80040
Let me know if you need more assistance.
Apr 08, 2009 | Kenmore Washing Machines
How do I replace the dog agits on a Kenmore model # 92597200? I have the agitor out of the machine but I need to know how to get the dog agits out.
pull your top and bottom of the agitator apart then the holder for the dogs should fall out when you turn it upside down
Jan 07, 2009 | Kenmore 24902 Top Load Washer
Broken Washing Machine Agitator
probably just what is known as agitator dogs just worn ..with no brand or model i assume it's a whirpool or kenmore ..1st remove softner dispenser (without brand can't say how it would come off ..some twist off some just pull off ) if agitator has cap underneath pull it off in center of agitator should be a bolt 7/16 if kenmore/whirlpool..remove it pull up on top half ..whole thing may come out if so just pull up sharply on top part..center part of top half comes out dogs are on it( 4 )again i'm assuming kenmore/whirlpool whirpool part # 80040 replace them and reassemble ..if any other brand will probably have to replace entire agitator..good luck
Sep 11, 2008 | Washing Machines
Agitator clicks in wash mode sometimes, stops agitation motion then returns to normal wash and click noise stops. Please comment. Thank you, fred elam
got a model # It may be in the gears of agitator if you have a 2 piece agitator... is the bottom of the agitator moving still when you say it stopped ?? AND Its Just Top of agitator stops?
Sep 02, 2007 | Kenmore 22932 Top Load Washer
Washing Machines Logo
90 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
