Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My machine fill up but will not agitate, Whats wrong with it?
I hear a humming sound like the sound of a motor . but its not loud.
  • Peppy1 Feb 20, 2009
    water fill fine on all setting, produce a short low level noise, small burning smell and stop; I have manualy advance to every cycle stages and all empty / spin cycles work fine but I can get any agitate cycle to operate;
    Could this be a timer clock issue.... PLEASE HELP
  • 117 Answers
Possible causes are a seized up drain pump or a faulty motor.
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
    Novelist:
  • 117 Answers
The humming sound you are hearing is the water valve either trying to open and can't or your water is shut off at the valve. Might want to check one final thing if either of the two scenarios above.....remove the washer hoses from the back of your machine and check to see if the screens inside the washer water valve are blocked. Good Luck! If I can help further, I am here.
Waiting to hear from you,
Eric Campion
Posted on Feb 14, 2009
Motor is running but won't agitate and belt is on ? I can hear the motor humming and it will fill up but it wont agitate.
Check drum turning by hand ok not sticky sounds like could be motor if it hums and no turn..
Oct 18, 2014 | Hotpoint Washing Machines
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
Doesn't agitate or spin but makes loud motor sound
check your motor coupling, it is between the motor and tranny
Feb 17, 2010 | Washing Machines
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
Washer will not agitate
There is either something stuck in the drain pump or the motor is defective. The drain pump is connected to the front of the motor, if you remove see if the motor works without it. If it does work, check to see if there is something stuck inside the drain pump or if it is seized.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Fills the hums loudly
Hello , Have you looked inside the pump where the hose comes from the tub , there could be an item clogging it , also try turning the pump where the shaft goes by hand , it should turn freely.
You can also try turning the gear case with the motor off where the coupler is attached , 1 direction will agitate and the other direction spins , you should be able to turn the gear case both ways and it will not turn easy.
if all of these check out the motor could be bad but it is highly unlikely.
let me know how it works and if you have any other questions.
Phil
Jan 08, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
89 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
