Question about Motorola Mobility H700 Wireless Headset
How do i put a motorola h700 bluetooth into discovery mode
I cannot get my bluetooth to connect to my vzLG8500
Close the mic and push down the button until the light shows purple. Flip open the mic and it should be steady purple. it's now in discovery mode and you should be able to sync it to you phone.
Posted on Apr 29, 2009
How do i sync my phone with the h700
Hi, Motorola H700 Bluetooth headset is a basic Blutooth headset that can be synced, or paired, with any Bluetooth-capable cell phone. Something unique about this phone is its retractable microphone, otherwise known as the headset's "boom." You can send and receive phone calls hands-free and wirelessly with your contacts using your H700 headset, in one touch of a button.
instructions
Press and hold the "Call" button on the headset for four to five seconds until the LED light glows purple.
Flip open the headset "boom."
Set your phone into "discovery" or "pairing" mode. Open the Bluetooth settings or options on your phone and choose to add a new device.
Select the "H700" on the phone when it finishes searching for Bluetooth devices.
Enter the passkey for the headset, which is "0000," to finish syncing the headset with your phone.
And your done..
Hope it helped.
May 30, 2011 | Motorola Mobility H700 Wireless Headset
I cannot get my motorola H700 to sync with my iPhone 3g. Bluetooth won't go into pairing mode
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 31, 2010 | Motorola Mobility H700 Wireless Headset
Can't pair bluetooth H700 to my phone.
Here is a detailed solution on how to pair your H700 headset with your phone;
STEP 1 You have to firstly put off the headset,by holding the call control button,which is the button on the face of the bluetooth,until the blue light turns red,as soon as the blue light turns red release the button.
STEP 2 After putting off the headset,wait for like 5 secs to ensure its completely off.when the device is off,you can now press and hold on the call control button for 5secs if its the first initial pairing,if it's not,then you have to hold on the call control button for 8seconds,afterwards the light should flash red then blue in both cases
STEP 3. At this point in time your headset is in discovery mode,and you have 60 seconds to pair it with your phone which should also be in the pairing mode as well.
To put your phone in the pairing mode,you have to put on the bluetooth of the phone which is found under the connectivity settings in the menu.
Your h700 headset and your phone are matched up and your problem is solved.
Thanks and take care
Aug 23, 2010 | Motorola Mobility H700 Wireless Headset
I can't connect my EnV2 to my Jabra Bluetooth. Is there a trick?
It could as easy as updating your phone by dailing *228 with a Verizon phone, select option 2 then press ok when the update is complete. When the phone resets, turn on the bluetooth headset, a prompt on the phone should come up to enter the passkey which should be 0000
Sep 01, 2009 | Motorola Mobility H500 Wireless Headset
Can pair my h700 w my bberry storm
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 16, 2009 | Motorola Mobility H700 Wireless Headset
How do I connect my motorola h700 to my samsung a137?
You can transfer files(pics,music etc) via bluetooth(both devices must have bluetooth).If so then in bluetooth setting enable discovery mode(show device to all) and you will need passcode(you can choose any combination of 4 digits).
Apr 27, 2009 | Cell Phones
I have a blackberry storm and im trying to pair my bluetooth h700 with it. it found the headset but it keeps saying connection successful the 2 seconds later itll say connection terminated. all my...
Jan 18, 2009 | Motorola Mobility H700 Wireless Headset
H-700 motorolla bluetooth
1. Bluetooth enabled?
Dec 19, 2008 | Motorola Mobility H500 Wireless Headset
I can't sync my motorola h700c with my blackberry
2. Options -> Bluetooth -> Add Device
Search for Bluetooth devices on the blackberry. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the blackberry and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the blackberry.
Dec 11, 2008 | Motorola Mobility H700 Headset
Motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
688 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
