Question about GE Profile Harmony DPGT750EC Electric Dryer
Blower motor inop. good power going to the motor. where can I get a maintenance manual? also looking for a blower motor part number and where i can order one.
  • 1 more comment
  • Bob Small Feb 19, 2009
    I have the same problem. Really, intermittant blowing.
    The thing to try FIRST is to check for error codes:
    Turn on the Dryer, If not on the home screen, press 'home' on key panel. press and hold "my cycles" and "back" together for three (3) seconds. If there are any codes it will say "Errors Recorded"
    One comment I found elsewhere was to unplug the dryer and let the compuer in it 'reset' - I think after 3 minutes or so - but I let mine go 10. Plug it in and see...
  • karam4kren Mar 08, 2009
    Same problem, Unpluged dryer to remove top and scematic, Found this site on the web, pluged back in after about 10 min and now works. Computer must have reset.
  • basisgod Mar 09, 2009
    blower does not work,no heat. the sears service man put in new thermostats and new board, still nothing.
  • 686 Answers
Check other solution i've posted
Posted on Mar 04, 2009
1988 Celebrity blower motor inop
check the resister is a couple inches away from the blower motor a bout 5 -6 wires
Apr 13, 2012 | 1988 Chevrolet Celebrity
Blower inop on auto or manual. burner inop.
Hi check out the fan control afc see if it is clean , check out pressure switch and the flame sencer
Feb 21, 2010 | Coleman Propane Forced Air Heater...
Blower fan is not working
Check your fuses
If they are all ok.
You may have to remove the right side, under dash, hush cover. (7mm or 9/32 socket to remove bolts) to gain accsess to the bottom of the blower motor
look up under the right side of the dash, with the fan switch on, bang on the blower motor with a screwdriver handle.
There is a good chance that it will come on.
The brushes get worn down and start sticking. they are designed to stay tight as they wear, but somtimes stick.
I found this to be the case in more than 50% of the blower motors inop.
If that doesnt work then test for power at the blower motor plug.
Hope this helps
If it does, leave some feedback.
(:DK
Nov 25, 2009 | 1999 Pontiac Grand Prix
Where is the front fan resistor unit?
Look under the van,on the drivers side near the radiator,it should be in that area.Follow the wires from the fans,they should go right to the module.This is for the cooling fans for the radiator.For the resister module for the blower motor look near the blower motor in the blower box.It is near the blower fan.It can be under hood,but it will be mounted with two screws.Remove the two screws,but you need to remove the wire plug in first.Pull it out .It goes inside of the blower box.If you replace this module,replace the blower motor also,because the blower motor is what causes the resistor to burn out.Did you check voltage at fuse with key on?If you did not check the fuse with key on,you got a false reading.If you checked the fuse with key on,look for a bad ignition switch,or a fusible link burned into coming off a pos. terminal post where the battery cable goes to under the battery.If the blower will not work at all even on high blower,the resister most likely not the resistor.The blower motor relay is most likely the problem.
Aug 29, 2009 | 2005 Dodge Caravan
A/c blower; inop
Check for power at blower motor connector with a/c on and blower on low if you have power I would suspect blower motor.
Jul 05, 2009 | 2004 Ford F150
Blower motor inop
Run 12 volts directly to blower motor to see if motor will run, if it does, than its blower motor resister thats bad, if it don't run than its blower motor motor thats bad. Most likely its the resister, common problem.
Mar 28, 2009 | 2002 Dodge Intrepid
I have a 1995 Buick LeSabre. The heater blower motor is inop in o
There are actually two possibilities for your issue. First is the blower motor resistor as you stated as a possibility. The blower motor resistor is usually located inside the blower motor housing unless the blower motor is mounted horizontally and is accessible from the engine bay (which I do not believe is the case in your Buick) in which case the blower motor resistor is going to be located in close proximity to the motor.
The other possibility is that the ignition switch is going bad. Now, this may seem strange at first, but GM ran much of the power for the accessories through the ignition switch and as a result, carbon builds up on the contacts and starts to affect the operation of the accessories. However, I dont think this is the case in your issue as that is normally accompanied by issues with other accessories like the radio and such.
I think it is more likely that the blower motor resistor is bad in your case. I believe your blower motor is located on the passenger side, against the firewall close to the center console. If you contort yourself in a way where you can look at the bottom of the blower motor housing you may see a connector on the bottom, or a small access panel. If so, that is likely the blower motor resistor.
Dec 31, 2008 | 1998 Buick LeSabre
1981 corvette blower motor getting no powere has power at fuse block but no where else blower motor runs with jumper wire
Check the blower speed control resistor pack, it is located in the air stream near the blower motor, that is most likely the cause of the inop blower, but be warned if the blower is drawing to much current due to wear the resistor will fail again, I believe the connector has four wires, 2 are heavy Gage
Jul 29, 2008 | Chevrolet Corvette Cars & Trucks
GE Profile Harmony DPGT750EC Electric Dryer Logo
95 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
