Question about Troy-Bilt Pony Garden Tiller
Tranmission will not change it is stuck in one gear
Last year it was hard to change gears
  • adrian halli May 11, 2010
    please check manaul to see if you can check you oil levels serparately ie;gearbox/engine if this the case then check oil level in gear box if low fill to level on dip stick.
I have a 1988 Nisan pathfinder 4x4 its stuck in fourth gear I've owed this vehicle seven years last year it started kinda sticking in fourth gear so I started bypassing fourth gear tried it again now can be that the gear oil is old and dirty so a sincro in the box is stuck to 4th are going to have to remove gearbox and investigate.hope this helps
Jan 17, 2016 | Cars & Trucks
Have a hyundai elantra it is shifting hard going in second no check engine light on. took it to a transmission shop they couldnt find anything wrong with the tranmission. what do i need to do next?
I've had the same issue in another car. Have a transmission flush/filter change and drive it. Mine lasted till I sold it 3-4 years later. it could be a stuck valve inside to regulate the pressure during the gear change. I would the flush a try.
Apr 06, 2014 | Hyundai Elantra Cars & Trucks
Tranmission wont shift
Gears inside welded together, or stuck in limp home mode. Is it stuck in a gear other than 1st or reverse? Limp home mode will select one gear, usually 2nd, when computer senses a problem with valve body pressure, or excessive heat. Either way it sounds like a trip to the ****** shop.
Oct 06, 2012 | 1999 Plymouth Voyager
The gear won't shift back into neutral on 1998 subaru forester 5 speed manual tranmission
i had the same problem with my toyota estate i had to remove the gearbox and remove the bottom plate then tap the gears with a hammer not to hard untill the gear moved then put it back together and worked fine never did it again and wasnt to hard to move the gear.
hope this helps i tryed rock banging and everything else before i took the gearbox out
Apr 28, 2012 | Subaru Forester Cars & Trucks
When driveing my car down the road the tranmission is in second gear when i am getting ready to go to third gear i push the gas a bit the rev goes to 2 and sits there for a second then the car would lurge...
When was the last time the trans fulid and filter was changed? Sounds like the filter in the trans is dirty. And if left over time will damage the transmission. Transmission fulid and filter should be changed every 35,000 to 45,000 miles. And it could be the shifting module on top of the trans (Netural Park switch)
Jul 31, 2010 | Ford Taurus Cars & Trucks
The tranmission wont change gears
If it is standard check your throw out bearing
Sep 30, 2009 | 1988 Ford F 150
Tranmission is hard shifting
Check the linkage to see if it's free and not stuck in any way. Also, where it's old it may need a couple adjustments on the rod located under the unit.
Aug 23, 2009 | Mtd LAWN MOWER PART # 17871D FENDER-REAR...
1994 s-10 stays in high gear
try and service the transmision filter and fluid and add a suppliment call LUBE GUARD u get this at NAPA/valve body is stuck
Jun 29, 2009 | 1994 Chevrolet S-10 Blazer
The gear is not picking as fast as it suppose to
When was the last time you have the tranmission fluids changed? Tune up? You should have a tune up every 40,000 miles..Bosch sperk plugs four tips! You shall see a big difference.
Jun 06, 2009 | 2001 Volkswagen Passat
Troy-Bilt Pony Garden Tiller Logo
388 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
