Question about Coleman Powermate 11 Gallon Air Compressor
Coleman 11 gallon air compressor wont start
Used one day,cut off. 2 days later would not work.
  • Jim London
    Jim London May 11, 2010
    hi, This is long distance troubleshooting and we seriously need more info. When you say cutoff does that mean you turned it off or it quit, 2 days later what won't work, no power, no pressure? Anything in the tank?
    New Friend:
Where is the reset located on the compressor
Posted on Dec 31, 2013
  • 25 Answers
Sometimes the initial start up with the tank at 0 psi electric power is adequate. However when the tank is full or the garage is cold it is a bigger load for start up. Check your overload (reset button) and breaker. If 220 volts one side of the breaker could be tripped without showing.
Posted on Feb 25, 2009
I have a Cleman 4 Gallon, 1.75 HP, Powermate air
When mine hums and trips, it is one of two things, Not warm enough, only does this when it is cold out, and 2 would be not enough juice, I have to have a 20 amp breaker or it doesn't run. And if I use a cord, it has to big. The slightest drop in amperage and it will not run, yours might have the same problem, mine is only 1 1/2 HP. It draws some 16 amps at start up and then idles down to 13 to run. A 15 amp breaker, forget it. Cold out, forget it. It wasn't just mine though, we did a house last winter and made one bathroom heated with a gas heater with 3 compressors in there just to keep them warm, there was no room for us. Hope this helps.
Jul 20, 2010 | Coleman Powermate 11 Gallon Air Compressor
Motor starts sounding normal then after 2-3 seconds stops & just humms.
I suspect the check valve is stuck closed causing excess high pressure in the cylinder and too much load for the motor. The check valve is OFTEN right at the tank where the compressor output line goes into the tank.
Jun 09, 2010 | Coleman Powermate 11 Gallon Air Compressor
Wont run while under load
ok buddy i know the problem before the pipe connects to the tank it goes to a valve unscrew this and check the rubber inside turning it around if necessery get back to me51a35be.jpg
Sep 19, 2009 | Coleman Powermate 11 Gallon Air Compressor
Coleman powermate compressor doesnt hold air
CHECK YOUR TANK PRESSURE ADJUSTMENT KNOB ON TOP A LOT OF TIMES THERE NOT SET AT THE FACTORY.HOPE THIS HELP'S
May 22, 2009 | Coleman Powermate 11 Gallon Air Compressor
Coleman Mach 3 Rv air conditioning
Dirty coils might be your problem. You might have a refrigerant problem as well. Try cleaning it first then have a tech put gages on it. Doesn't sound too serious
Jun 12, 2008 | Heating & Cooling
COLEMAN TSR MACH 3 COMPRESSOR
I would check the thermostat based on what you said it could be out of calibration
Jun 11, 2008 | Coleman Mach 15 Air Conditioner
Coleman Powermate 11 Gallon Air Compressor Logo
504 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
