Question about Sony DVP-S360D DVD Player
No video/audio on tv when powered up and running
Just got Comcast Digital. TV and VCR and DVD.. DVD has no video/audio Display shows it is running.TV and VCR work okay
Apparently it is not reading the DVD. Should I call Comcast or tech at Best Buy who hooked up cables. Any suggestions?
Drew a diagram of the back of each component & wires/cables and emailed it to my grandson,
The video wires in the VCR were placed out instead of in. That solved the problem Thanks.
Posted on Feb 15, 2009
Problem with video signals through AVR-4800
Pic of product.
Owners manual
I'll be back after I study it, if problem persisit
Check monitor 1 settings in the on screen display on tv for me
Jan 13, 2008 | Denon AVR-4800 Receiver
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
I have no TV box but do have cable, how do I hook up TV,VCR,DVD, and YAMAHA HTR 6030
For watching TV, your TV should have a monitor out. This will go to your CBL/Sat input on the receiver. If you have a newer TV, it will have an optical output,if you use that, you will have Dolby Digital surround when available, and digital stereo at all other times. For the VCR and DVD, if they are separate units, Run audio video from the VCR to the receiver to VCR 1, for the DVD, use Component video and optical or digital coaxial to the receiver. Then from the receiver run component video to the TV. If you need further help, post a comment and I will help you further. Hope this helps
Dec 28, 2009 | Yamaha HTR-6030 Receiver
APEX Digital VCR&DVD PLAYER ADV-3800 will not play DVD's.
What it so far done, it looks pretty fine. I'd break apart the problem if is posible to do it, i mean maybe you have some other sets around the house or some friend who have them.
  • i'd test the dvd/vcr in a different tv
  • i'd test the tv with a different dvd
i would start over again the installation after this test.
the reason is to know if you can trust in those sets and second maybe with some other try the installation works
May 01, 2009 | Apex Digital ADV3800 DVD Player/VCR
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
DVD is wired to the VCR and does not work
The Sony Bravia should have a number of component inputs, so you should be able to hook up the DVD directly to the TV. The only reason for hooking it up through the VCR would be to record a DVD on VHS... but that's for the birds--VHS is old technology.
Each component input on the back of the TV has a number. You then select to view the component you want by pressing the remote control button to change the display (it should show with one you're on... e.g., Video 1, Video 2, Video 3, etc.).
Dec 24, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do I connect the VCR & DVD when I have a Comcast box
Good Day,
Not knowing what type of TV you own, let's try this:
1. Hook your Audio from your TV to your amp; TV's audio output to an amp input.(eg; video one)
2. Hook vcr/dvd/c box to inputs to your TV.(eg; vcr to video 1 on tv, dvd to tv's video 2)
Let me ask you how many inputs does your tv have?
Is tv, box&dvd HD?? Iwill help but give me more information. Thanks
Jun 11, 2008 | Televison & Video
If using 3 color RCA (r/w/y) the red and white is audio and should go into your stereo under video or AUX. The yellow is the only video cable you need, that should go to your TV aux in or video1 or video2. You can also put all 3 colors into the tv and then run another red/white OUT to the stereo AUX in and have stereo sound for whatever you are watching.
Feb 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Sony DVP-S360D DVD Player Logo
65 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
