Question about Whirlpool Washing Machines
Whirlpool Clothes Washer Model LSR7233DWO Cold Water Fill
For a couple years we've (wife and I) been putting up with a sloooow fill on our Whirlpool Washer. Of course we use Cold water wash more often these days in order to save the planet and do our share to reduce global warming.
When filling there is a noticeable hummm and today wifey and I decided to open lid and look. (actually it was wife - she called me over to look)
She opened the lid and I gazed in with amazement.
''You can open these things while they're running!?''
She hit me.
I was looking into the machine struggling with the urge to hug her for displaying mastery of the machine.
Suddenly she began to change the water setting from Cold to Warm wash.
Each time it went to the Warm setting the water went from two seperated dribbles to a 7 inch wide ribbon. Reminiscient of a water feature you'd find in some fancy hotel lobby.
I couldn't help myself....
''Something's wrong!'' I blurting out.
She rolled her eyes mumbled something and walked off ..
I am guessing there is a solenoid activated inlet valve doing a poor job.
When the water stops and the cycles end I'm gonna rip it apart and look.
The present wash was started at 10:30. It is now 11:57 and the machine just completed filling.
She's (wife) setting up '911' on the speed dial in anticipation ......
    Novelist:
  • 117 Answers
It is a common problem. The water inlet valve (the item your fill hoses attach to) has a problem. first thing I would do is remove the hoses and check the screens inside the walve itself. If blocked, clean them. IF they are OKAY....WHile the hose if off place it in the washer tub and turn it on full blast. Does it flow with force? If so, you will need to replace the water inlet valve. While on cold....it trickles and turning it to warm, the machine sends power to both the hot and cold water solenoids and then you are forceful. Mostly hot and a trickle of cold.....Get the point? If I can help further...
Waiting to hear from you,
Eric Campion
Posted on Feb 14, 2009
My Whirlpool Cabrio washer model WTW5610XW0 type 588-02 spins then stops and clothes still come out wet.
The washer is unbalanced, make sure it is level and the clothes are distributed even, if this have been check. put the unit on cold water and see how fast it comes in. Safety programmed into the unit if it takes longer then 10 minutes to fill it will just drain. This is to keep the washer from flooding out. Check the water inlet where the hose screws on, it could be plugged up with grit
Dec 12, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Won't fill
Try putting the clothes in and filling it with a bucket via the top opening (Cold water will do)
If it starts and washes then it is the fill valve which has gone faulty , if you put in the normal fill level and then exceed by say another bucket full, that indicates it is the pressure switch.
Ps
You might try taking the fill hose off the back of the amchine and clean out the small filter which is just inside the opening
Jan 24, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My Maytag clothes washer won't fill with hot water
Then you most likely have a bad hot water valve. On Maytags the valve is one combo unit for both hot and cold. Maytag didn't change that much for a number of years, so you may be able to salvage one out of an old machine somewhere and fit it in -- that's what I did when my wife's Maytag did this.
Dec 30, 2009 | Washing Machines
Whirlpool Duet GHW9100LW1 fills up with power off
You have a faulty fill valve
If you want to check which one, try turning off the cold supply only before you go to bed
If the washer has water in it next morning it is the hot valve that has gone faulty if it is dry then it is the cold one
They are easy to change and can be bought from a number of suppliers
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Green whites?
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Small brown spots on whites
Nov 15, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
173 people viewed this question
Dan Webster
Dan Webster
Sal De
