Question about Refrigerators
Haier Thermoelectric Wine Cooler
I have a Model: HVUEB06BSS wine cooler that was working fine until I turned of a circuit breaker to fix a broken socket in the garage. I was unaware that the circuit in the laundry room where the cooler was plugged in was on the same breaker. After turning the circuit back on, the cooler was no longer working. When the cooler is plugged in and turned on, the display lights blink and the temperture display comes on but the cooler will not stay on. I removed the back panel and looked inside but there is only a circuit board and there is no reset switch. Is there anything I can do to fix it or should I put it out for the trash?
  • 3 more comments
  • gbragg Feb 14, 2009
    The model number I gave is correct. The serial number is 070908443. It is actually not under the Large Appliance/Refrigerator catagory but I could not find a catagory for wine coolers. The unit was made in China 0907 (I assume that is Sept. 2007). Sorry for the inconvenience.
  • gbragg Feb 16, 2009
    I left the door on the unit open over night with the power unplugged. Upon plugging it in again, nothing happens but the temperature display flashes. If I press the light button for lighting the inside of the cooler, it also flashes. Pushing the temperature up and down buttons doesn't seem to do anything.
  • david0901 May 24, 2009
    I have the Haier HVUEB06BSS wine cooler. I have simular problems. The unit was in a laundry room and one day just stopped cooling. I have all the lights, controls, temp readings working. No blinking lights...just acts likes it is working fine, but will not cool at all.
  • Jim London
    Jim London May 11, 2010
    Hi, Can you check that model number? There are no codes on the display?
  • 257 Answers
Hi, Well not much to go on but this is not a complicated unit. Please bear with me as we go back and forth for this type of long distance troubleshooting. The control board on this type of unit uses ambient temperature and that is what should be displayed when first turned on. Knowing that; the unit will not run if the setpoint is lower than the ambient temp. The unit operates on 27F degree difference from ambient. So lets do this, unplug the unit, remove your stuff if any, open the door for a couple hours till the unit stabilizes to room temp. Close the door, plug the unit back in and note the display. Move the setpoint to just below whatever your room temp is, if there are dashes it indicates a temp problem or the sensor that needs to know the difference. Good for now, let me know. Thanks and Good Luck!
Posted on Feb 14, 2009
  • Jim London
    Jim London Feb 16, 2009
    Hi, Well it sounds like the control board was damaged. Since this is a relatively new model number is this unit under a year old? It has a full 12 month warranty if you have the receipt. Parts are only available thru Haier America, Their customer service number is 1-877-337-3639 Good Luck to you!
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
Does a thermoelectric wine cooler have a ventilation system?
Absolutely, every wine cooling system has to have a ventilation system that will channel the heat generated in the operation, outside of the unit, including the thermoelectric wine cooler.
Aug 14, 2012 | Furniture
Can I install a thermoelectric wine cooler as a built-in cooler?
No. If a thermoelectric wine cooler were built-in, it would not be able to dispel the heat it emits and the fridge would not be able to reach the necessary temperatures.
Jul 31, 2012 | Furniture
Why should I buy a thermoelectric wine cooler as opposed to a compressor model?
There are many reasons to purchase a thermoelectric cooler including, but not limited to, being quiet and eco-friendly. Personally, I prefer thermoelectric coolers because they don't vibrate. The vibration of a compressor cooling system can cause the sediments in the wine to be disturbed and affect the flavor/taste of the wine.
My Haier wine cooler (Model BC112G) has stopped working. Prior to it stopping, the pipes in the lower back became caked with ice. Any ideas what might have broken...and how/if it can be fixed?
let the thing totally defrost (24hrs)with the door open then switch it back on as a first step,the ice on the pipes stops the gas from turning from a liquid to a gas...thats how it cools..
Jun 03, 2010 | Haier BC112G Wine Cooler
I need a circuit board for a Haier thermoelectric wine cooler model no. HVW12ABB Part no. GCH-A11
My Kenmore mini Refrigerator has this same board. One capacitor has popped its top.
Oct 07, 2009 | Haier HVW12A Wine Cooler
Thermoelectric plate does not appear to transfer heat
you should see if theres a DC voltage going to the plate or not. it should noticeably heat up instantly with proper voltage applied. if power is there and it doesnt heat then the thermoelectric device needs to be replaced. also you should be able to measure a resistance of the plate. Should not be shorted or open. it should be a relatively low resistance. like a few ohms. and it may read different depending on which direction you connect the leads.
Aug 02, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Refrigerators Logo
676 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
