Question about Singer Sewing Machines
Dismantled thread tension dial on a singer 287 sewing machine
Someone trying to help me sort out the tension on a singer sewing machine,that ive borrowed, took the entire tension dial off and i dont know how to put it back together.please somebody advice me on how to put it back on correctly.
maklean
  • 1665 Answers
SOURCE: help!
Have a look at link it may helps
http://www.repairsewingmachine.com/
Posted on Aug 09, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
Mimito7
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
Mimito7
  • 128 Answers
SOURCE: No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
Zenqi
  • 208 Answers
SOURCE: Singer Featherweight tension assembly
Putting this back together is a thirty second job if you have done it a hundred times. If you have never done it but have mechanical aptitude, it may be a challenge.
Whatever you do, don't bend the check spring out of shape!
Below is a link to the Singer site with the schematic for reassembly. When placing the check spring back in place, place it in about the 6 o'clock position with no tension so that it has a fair amount of check before pulling it up in place..
When setting the tension, at a setting of "1" the tension disks should just be slightly compressing the beehive spring. "0" is almost no tension at all. Normal sewing is 5.
Get all of the parts together and push in the cup with the numbers while screwing on the knurled nut taking care to get the pin in one of the holes.
http://www.parts.singerco.com/CPpartCharts/2_2999/221-1_221K1_221K4_221K5.pdf
Posted on Jun 19, 2009
My Singer XL 6000 upper thread is too tight and keeps breaking, when the presser foot is up the upper thread is loose, but when the presser foot is lowered the threah gets too tight, what I notice is that...
You need to loosen the tension on the machine. There is a dial that has numbers on it. The higher the dial is set, the tighter the tension is. Turn the dial to the left one number. Then try it. Do it over and over. Do not turn the dial all the way down or you will mess up your machine. Do it slowly, one number at a time and try the machine between dials.
Dec 22, 2014 | Singer Sewing Machines
Seconds after some sewing the machine cuts off the thread...
The tension is too tight, adjust the tension dial down to around 4ish and see if that helps.
Jan 24, 2014 | Singer Sewing Machines
Singer 2263 loops on top of fabric
try changing the needle
thread the machine, use every thread guide
there could also be something wrong with the tension dial, it would
be a good idea to have the tension dial checked
Sep 23, 2012 | Singer Sewing Machines
How do you thread a singer merritt 1872?
Wow, one of the few Singer machines that doesn't have a free download manual. Hmmm..... Ok looked up a photo of your machine. It's pretty easy.
1. raise your presser foot.
2. Put thread on spool pin.
3. draw thread over to and under from behind of the pre-tension disc at top
4. Draw thread down from the right and under the tension dial to seat the thread into the tension discs and flex that spring a little.
5. Through the take up lever.
6. Down through the thread guide.
7. Down through the needle bar thread guide.
8. Through the needle.
Hope that helps.
Aug 20, 2012 | Singer Sewing Machines
Tension problem old singer sewing machine
try rethreading the machine top & bobbin to make sure the thread is not caught
somewhere
change the needle
if the tension dial does not respond then the dial may need to be replaced
Apr 12, 2012 | Singer Sewing Machines
I recently rec'd Singer Curvy 8770 as gift. Trying to use for first time and thread on underside of stitches is loose. Have tension on top dial as far as 9. I hve been sewing for forty+ yrs.
Try this, totally rethread with the presser foot up, then pull the top thread, it should move smoothly, then lower the presser foot, now pull the thread, it should barely move. This seats the thread in the tension discs.
Apr 11, 2011 | Singer Curvy 8770 Electronic Sewing...
Singer 6105 Tension knob & dial has been manipulated to make proper stitches. Still loops at bottom of fabric. Rechecked bobbin. Cleaned & oiled machine top to bottom. Would I need to order a new...
First make sure that the thread you are using in the bobbin is the same brand and type as in the spool that is threaded. I've read that using different weight threads at the same time can cause tension problems. I have actually had this problem and following this advice it went away. If this doesn't work you may need to have the machine serviced, unless someone else in the forum can advise otherwise. Good luck.
Jan 13, 2011 | Singer Sewing Machines
Bottom thread Ravel when sewing
take thread completely out. rethread, pull your foot lift up before threading. make sure thread is in the tension disk of you dial and notice if thread is a little tougher to pull when u put foot down...
May 27, 2010 | SINGER 7470 Sewing Machine
I had to rethread my Singer Ultralock serger and now it won't sew correctly. Best I can tell the lower looper keeps coming unthreaded, but this doesn't happen until I put material in. I have rethreaded it...
I had read where someone said their lower looper tension dial had pulled apart. Sure enough, mine had too. We snapped it back together and Voila problem solved!
Dec 06, 2009 | Singer 14SH654
The threads are not tight on my serger
Here is an easy way to get your thread adjusted. Rethread the machine using four different colors. Then sew and for example the "yellow" thread is loose on the fabric, you know to adjust the tension with the yellow thread. Also a good starting place on your dials is 4-3-2-1 from left to right. Start with the tension set there and then adjust as needed.
Dec 20, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
259 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
