Question about Vivitar ViviCam 35 Digital Camera
Cable Is there a DV cable that connects from a Vivitar 6324 Camera to a DV input on a DVD recorder?
    President:
  • Vivitar Master
  • 1,734 Answers
Depends on your DVD recorder input interface. If it has a USB connector, it should work. Maybe you will need a driver. You can get the software from http://manualfox.com
Just send them a request.
Posted on Mar 28, 2009
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
How connect Magnavox DVDR to Comcast Cable Box ?
You'll need to use the direct input on the rrcorder from the DVR video output.Some channels won't record as they're encoded
Sep 25, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
I set up my camera cd driver(panasonic nv-ds65) on my pc and then connected cable to camera (dv slot) and pc(usb) ,and couldnot download movie(on the type) to pc ,but i could download pictures to pc by...
you just need cable with both end DV pin.its mean one end you have dv out put then where you input also need DV in put so need both side DV pins.after that you can download your movie on pc.
Oct 23, 2010 | Panasonic NV-DS65 Mini DV Digital...
I'm getting a message "Camcorder not connected. I can't program any recordings
When this recorder reads 'not connected to camcorder' you are simply accessing the recorder's 'DV' input on the front panel of recorder. This 'DV' input is used with DV Camcorders, thus the message.
Simply hit the 'AUX' button on the remote control to access the recorders other inputs. It will cycle between-TUNER>>AV1>>AV2>>DV.
Depending on what you want to access or view and where they are hooked up to the recorder. The "Tuner" will access either your over the air digital channels or your basic cable channels when hooked up through the 'UHF/VHF' input on the rear panel.AV1 is input 1 on the back of the recorder. AV2 is the input on the front of the recorder. DV allows for a Digital Video Camcorder to be hooked up to recorder using a 'Firewire'.
Oct 29, 2009 | JVC DR-MV100B DVD Recorder/VCR
I am a member of a paranormal group. Can I use my magnavox MWR10D6 DVD recorder to record from a cam. Is this possible?
As long as your DVD recorder has line inputs yes you can.
If your DVD recorder has a DV input, you can use a firewire cable. If your DVD recorder has audio and video inputs you can hook the output of your camera to the line inputs of your recorder and record in realtime
Most DVD recorders do have inputs, you can use either the Y/C (black round connector) or the composite (yellow connector) along with the audio inputs (red & white) RCA plugs depending on the type of camera you are using.
Sep 24, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I can not select input source, even though AV1 is connected. Pressing INPUT button has no effect. All I can see is ''Not connected to the camcorder'', which is true - but I want to record from AV1.
Press INPUT repeatedly to select the external input
to record from.
DV IN jack.
This recorder is only compatible with DV-format
(DVC-SD, DV25) camcorders. Digital satellite tuners
and Digital video recorders are not compatible.
Make sure your cables are connected correctly, if an audio cable is plugged into the video the unit wont see it.
Sep 05, 2009 | LG RC897T DVD Recorder/VCR Combo
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Sep 27, 2008 | Televison & Video
Trouble recording to DVD - connections are not done right - Sharp DVD-RW340
I had to run from the RCA outs of my DVR into the inputs that are on the front right of the RW340...behind the little door.  Now I can easily record from live cable or from my Comcast DVR recorder.  Couldn't get it to work from the backside inputs.
Mine is just the DV RW340 (no U).  And yes, the manual is brutal.  We had to call tech support to find what disc will actually work in the darned thing.
Now my big problem is finding more 4x DV-R disks. Shoulda bought more when Comp USA was clearing them out a few years ago!
I have had great success with Dynex Model: DX-DVD-R25 discs.  And they play equally nicely on my Toshiba DVD player in the livingroom.   I have also given several away to people after I had transfered home videos to DVD and those people all had good results playing the discs that I made on my lowly Sharp Dv-RW340.
Sep 13, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Transferring to DVD?
Maybe when you play the 8mm tape on the TV and have DVD/TV recorder hook up to the TV.
Oct 23, 2007 | Sharp Viewcam VL-A111U Camcorder
Vivitar ViviCam 35 Digital Camera Logo
63 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
