Question about Husqvarna Sewing Machines
Threading problems with Huskylock 430
Yesterday, my machine was working perfectly...finishing tablecloth edges for church event. Then when I changed colors of thread, it wouldn't sew at all. I have followed diagram on machine, diagram in instruction book, still no looping at all. I can't see problems with threading. (this is not a new machine, I've used it for years with never this much trouble).
Does anyone know exactly how the different threads should be positioned under the presser foot? All the diagrams just show dangling ends. I feel like there is some detail I'm missing to make them come together to form the loops.
SOURCE: threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Posted on Oct 20, 2008
safenude
  • 124 Answers
SOURCE: HUSKYLOCK 430
Welcome to FixYa! I'm the expert that chose your issue to solve. If you are happy with my service, please reward me with a "FixYa" rating and a comment so that I can continue to improve my customer service.
Husqvarna doesn't have a method to download instruction manuals directly from their website since they work through a dealer network. However, there are a number of online dealers and this one in particular has a manual that you can download for $5.00 or you can buy a print copy from them.
http//www.mastersewusa.com/info_hv_430.html
Regarding your footpedal, this company also sells accessories online. If, on the other hand, you want to find a local dealer, you can use this link:
http://webservices.us.vsmgroup.com/DealerLocator.aspx?Brand=Viking
Thanks again for using FixYa!
Posted on Jan 31, 2009
kent581
  • 87 Answers
SOURCE: Viking Lily - free motion quilting - thread loops on underside.
I need more info.
>Where is your presser fooot pressure set(1-9) it should be around 4?
>How fast are you free motioning (faster is better? from 1-10 10 being full speed.
>Is your bobbin threaded correctly (I need to cover the basics.)?
>Never never use a needle smaller than a 90/14 for free motion (I know everyone's an expert...but trust me)
After all this, it's OK to tighten your tension up on top a little when free motioning and getting eyelashes/spider webs on bottom. around 6 should do it though.
Posted on Mar 19, 2009
sew dutch
  • 24 Answers
SOURCE: Thread looping on the bottom
Thread looping on the bottom means you have a problem with the top thread. In your case there is no tension on your top thread. Take all the thread out of the top and start threading over. Make sure you follow the correct path and make sure the thread goes through the tension discs. Then at the time of sewing, make sure your foot is down (this closes the tension discs and gives the thread the tension.) You may have worked on the tension setting while not realizing the thread was not in between theses discs, so also make sure the top tension disc setting is in the average before sewing.
Good luck.
(If you see loops on top, it means you have a problem with the bottom thread)
Posted on May 25, 2009
Zenqi
  • 208 Answers
SOURCE: I need a threading diagram for a Viking Huskylock 560ED serger
Call Husqvarna Viking at 440-808-6550 and they will email you a PDF of the manual.
Posted on Oct 01, 2009
Viking Huskylock 560 ED threading diagram
Viking 560 ED Huskylock Handbook
Threading Serger this may be helpful even if it is not the same model. The sequence of threading loopers is VERY important. If you thread them out of order, be prepared to be frustrated beyond belief!!! Something else (I don't think she mentioned) is to ALWAYS RAISE the presser foot when threading your machine. This is true for sergers AND sewing machines!
How to thread Serger
Nov 17, 2016 | Sewing Machines
My Huskylock 936 won't sew. I was sewing yesterday, 4 thread overlock. I finished a seam, cut the thread, proceeded to sew another seam. I put my foot on the pedal..and nothing.If I turn the machi
Good evening madam
It sounds like there is something wrong with the electrical system in your sewing machine. You can check the power and connections.
good luck
Kolbrun
Feb 26, 2012 | Husqvarna Huskylock Computerized 936
I have a Husqvarna 936 huskylock which is about two years old. I have not used it much yet and yesterday I set it up to do a cover stitch for the first time. Since then I have spent hours threading...
For the cover stitch, only use a size 90 needle. Depending on the type of knit, use a ball point or stretch needle. The 936 uses standard sewing machine needles, so you can switch needles with the type of fabric, just like with a sewing machine.
Jun 29, 2011 | Husqvarna Huskylock Computerized 936
Threading a huskylock 234d serger
I have seen some models with a diagram for threading. Look inside the cover, in front of the machine.
Jun 01, 2010 | Sewing Machines
Sep 30, 2009 | Sewing Machines
Threading problem...for the huskylock 560 ED T
You can see a video of the threading of your machine at:http://www.husqvarnaviking.com/mediafiles/huskylock/index_en.html
You'll love it!
Aug 11, 2009 | Husqvarna Huskylock Computerized 910
Huskylock 430 - STOP BLADE FROM CUTTING/REMOVE BLADE
Yes, you should be able to just push in on the blade and flip it up out of the way. Page 22 of the machine's handbook shows how to change the blades, so you should be able to remove them the same way.
Feb 13, 2009 | Husqvarna Huskylock Computerized 910
Huskylock SL3003 Overlocker
I also have a Huskylock SL 3003 which I have not used for many years. As I usually keep the manual with the particular item, and there was no manual with the machine, I presume there was not a manual for this machine. (I also found Husqvarna useless!)
There is a website which copies manuals for sewing machines and I have asked them if they can find the manual for the SL 3003. As yet I have not had a reply. I only requested this on 1st September, so am still waiting hopefully. You may also wish to use this website: www.sewing-machine-manual.com or relics.com
Also, on the front of the machine is a slide with a thumb indent. Push this to the right and it will release. On the machine inside this door are the instructions for threading.
Good luck
Jun 11, 2008 | Husqvarna Huskylock Computerized 936
Huskylock 910
I received a cd with my machine showing step by step how to thread it. I put the machine beside my computer and threaded it step by step by watching the cd. One problem I had after threading it was not being able to sew a chain without the thread matting up and making a real "mess". The problem was I did not push the thread up against the machine until it clicked. That sets the tension. Try that and if you still have a problem email me and I will try to help. HisOwn2@triad.rr.com
May 20, 2008 | Husqvarna Huskylock Computerized 910
Sewing Machines Logo
111 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
