Question about XFX GeForce FX 5200, Graphic Card
No picture on tv
Hi ,
I have connected the Yellow plug and cable from the PC card (GeForce FX 5200 ) to TV, But no Picture on tv.
the picture is only on computer's monitor .
Please Heeeeelp,
Thanks
  • 3 more comments
  • Anonymous Feb 14, 2009
    I am using Win XP
  • moshest22 Feb 14, 2009
    I am using Win XP
    Dear Bubbabear64,
    On the settings tab I can see only the computer 's  monitor,
    1 and 2 as your pic do not appears on my screen .
  • moshest22 Feb 15, 2009
    I have load drivers.
    OK now.Many Thanks
  • Tim Babcock
    Tim Babcock May 11, 2010
    This is tricky.
    What operating system are you using?
  • 2,794 Answers
Move your mouse over to a empty part of the desktop and press the right mouse button. Select properties.
Make sure that your tv is connected to the computer, that it is turned on, and that it is set for line input on that device.
Select the settings tab. You should see this box appear.
Monitor one is your computer monitor. Monitor 2 is your tv. It should be greyed out. If you move the mouse over to 2 and press the right mouse button make sure the attached is checked off. If not do this right now.
You may have to click on monitor two as well and select the advanced button on this screen. Then look in the settings to turn the tv on (this happens with ATI cards, NVidia cards may have a similar setting as well). Once it is turned on and you hit apply the picture should come on the screen. If you check off extend windows desktop onto this monitor, you will only see the desktop without any icons. Make sure that feature is disabled when you use monitor 2 (by default it is).
This should keep you busy to get it to work. Let me know if you need anymore assistance on this.
Posted on Feb 14, 2009
  • Tim Babcock
    Tim Babcock Feb 14, 2009
    Is that an Nvidia card? If so go to the website and make sure you have the current video drivers. See if there is any settings for enabling the secondary monitor using the advanced button in the picture.
Radeon 7000 series
you can connect your video card to your tv by either a dvi to hdmi cable or s-video. There is no need for 2 graphic cards unless you want to connect more then 2 monitors.
Feb 23, 2012 | Nvidia GeForce FX 5200 Video Card Graphic
I have a GeFORCE FX 5200 PCI card, and onboard graphics. I had to restore my system, and cannot find the user manual. If it was available online, I'd follow the steps myself, but I'll settle for a quick...
Hi.
You do not necessarily need to disable the built in graphic adapter, the computer can manage two different adapters.
The nVidia should show picture with standard VGA definition (800x600 only) if simply connected to the AGP or PCI slot even if drivers are not installed, and even if built in GPU is not disabled.
If there is no picture, check installation in slot, check that card is not disabled in BIOS, check video cable is well connected, and if nothing works, test the video adapter on different PC, the card may be faulty.
Here the manuals:
Quick Guide to NVIDIA GeForce Desktop Graphics Processors
GeForce FX 5200/5500/5600/5700/5900 Series
GeForce FX 5200/FX 5600/FX 5900 Series
nVidia GeForce FX5200 Gigabyte GV-N52128DS manual - GeForce FX5200 ...
Sep 30, 2010 | Nvidia GeForce FX 5200 Video Card Graphic
I put mu s-video cable in the comp and in the tv and there is no signal and picture,like nothing happens i tried i settings ang graphic prop and there is nothing that i can klik ti say tv ???
make sure your tv is set to the correct avi or input that your using for the laptop conection to it. hope this helps, normally should just come onto the tv. once the tv is on correct station so to speak.
Dec 04, 2009 | Nvidia GeForce FX 5200 Video Card Graphic
NVIDIA GeForce 7300GT TV-OUT issues
You could try selecting properties on the shortcut and checking the run maximized box. Or you could try to find the .txt file with the game settings in it and manually insert a resolution. However, since I do not have the game, I cannot tell you were to find that. I hope this helps, Yannick.
Jun 09, 2009 | Nvidia GeForce FX 5200 Video Card Graphic
No signal on HDTV
Your graphics card is probably too old to support HDTV signal (720p, 1080p)
Dec 04, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
Internal TV Tuner card(Techom brand) capturing problem
try to use your graphic card on a different pc and use the same methond and check whats gonna happen after wards solution to this it`s either your mother board or ur graphic card
Apr 29, 2007 | XFX GeForce FX 5200, Graphic Card
Nvidia fx 5200
The only time that this can happen is if the driver is not installed correctly, as on install you are normally asked if you want to activate support for dual monitors, so if you havent already, uninstall the card driver, restart and install driver again from the cd or from the NVIDIA website. http://www.nvidia.com/object/winxp_2k_93.71.html If you have already tried this my apologies.
Apr 09, 2007 | Nvidia GeForce FX 5200 Video Card, 128MB...
Nvidia geforce FX 5200 having poblems booting pc....
as your primary pc now has a working graphics card . I would guess your graphics card is fried in all honesty there is really no hope in repairing it especially for the cost of one of those cards, if you are simply using your second pc for non graphic intensive apps then I am sure you could find an ol pci grpahics card down the local dump for next to nothing hope this helps. Genius2k4
Oct 12, 2006 | Nvidia GeForce FX 5200 Video Card, 128MB...
XFX GeForce FX 5200, Graphic Card Logo
108 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
