Question about E-Machines etower 533id PC Desktop
No sound etower 533id win98 os
Ran the restore cd to restore the sound. After rebooting, error message"CWCPROPS.CPL" appeared. Emachines says the driver is Crystal CS4280 3D PCI Audio. Other driver sites tell me this is the wrong one. I also don't know how to open a zip file.
  • 131 Answers
I would try the driver files that Emachine says is right for your computer first before any others. On windows 98, you will need to download a unzipper program such as winzip or RAR to unzip your files. Windows 98 did not ship with a unzip program attatched. once you install the unzip program, double click your zipped file. this will bring up your unzipping program. Choose "unzip all" and make sure you know where the files are unzipped to. Go to that location & look for a "setup.exe or install.bat " file. if there's not one of those, go to your device manager, pick your sound card & click "update driver" then browse to the location that you unzipped the files to, and click "OK"
Posted on Feb 15, 2009
I restored my emachines computer back to factory setting using the disk that came with it and now when I try to download a CD it says
i assumed your os is window xp....try this steps;
1. right click on my computer, left click on the properties
2. select the advanced tab, under performance click settings
3. on the advanced tab, under virtual memory click change
4. Under Drive [Volume Label], click the drive you want to change
5. Under paging file size for selected drive, select the custom size
6. type 384 in the initial size (mb) text box
7. click set and then ok
8. close the dialog and restart
i hope this help.
Jun 13, 2012 | eMachines W Computers & Internet
I have an old laptop that partition and hd have been reformatted. I've tried using boot disk but keep getting the message that says, ''save to disk partition not found. So, can't get win98se to load as...
Haven't used win98 for a while so bear with me and this uses DOS COMMANDS too.
If useing restore cd/floppy you have to use a utility from compaq that creates two partitions on hard-drive.
They may have a restore floppy if you need it too.
One for "recovery files" and one for "OS Boot"
AHH, the memories, I still have my 95/98/ME Laptops up and running for older stuff. HP n CQ too.
Restore CD should do it all though.
If no restore CD - have Win98 CD?
if Harddrive partitioned and formated - Just do 1
1. boot from Win98 CD.
Partition n Format
2. Choose boot to DOS (puts u in virtual drive A)
3. Type drive letter of CD ( C: D: or E: )
4. Type CD Win98
5. Type Fdisk ( to partion drive)
reboot n do 1 + 2
6. Type format C: ( I do this to ckeck drive for errors)
JUST Boot from CD and follow install instructions.
1 to 6 for if you have problem with Win98 CD setting up Harddrive.
Apr 04, 2010 | Compaq Presario 2140US Notebook
Win98 does not recognize the Maxtor OneTouch III 500Gig.
First I will want you to know that support for win98 has long reached end of life. I don't think that win98 support mass storage unit of that capacity. I will suggest you opgrade your os to winXP
Dec 28, 2009 | Computers & Internet
Unable to reinstall OS for Compaq Presario 5000.
Use ontrack disk manager
select advance installation
make partitions own do you want
after the completion process
take reboot
now install operating system that you like
even 98 or XP.
It will work 100% guaranteed.
Thank You
Aug 09, 2009 | Compaq Presario 5000 PC Desktop
Computer boots up then shows windows 98 scrren
you may face either harddisk failure, a driver problem or virus infection:
tools: original win98-cd (or a bootable image
version of it), antivir-software on cd!
- please check whether it is possible to boot from win98-cd, with cd-rom support, not from harddisk.
(such option should be availabe after bios-load is over)
if not:
leave the setup process without fully installing
(press F3 button when asked for repair or install option)
in both cases :
type at the dos-prompt:
(command for changing to harddisk, windows-folder, booting windows from harddisk, but without loading all the drivers as usually)
win98 should come up in protected mode or give error messages.
- access cd-drive and execute vir-scan.
- delete and/or repair infected files
- turn down, attempt to reboot from hd
- if still impossible reboot from win98-cd,
run repair of installation and try once again
standard boot
problem solved? if not, take down error messages consult fixya again!
Jun 13, 2009 | Dell XPS M140 Notebook
If it is in original configuration system restore would be on D: drive partition
Mar 10, 2009 | E-Machines etower 633ids PC Desktop
sounds like your cmos 3 volt battery is dead and needs replaced.
its a very small coin size battery located/hidden inside the laptop.
you will have to google the placement or just find it.
Mar 24, 2008 | IBM ThinkPad 380ED
Computer won't reboot
Check your BIOS settings, specifically the diskette drive setting. Next, check the cabling to the drive itself. Your problem may have nothing to do with the diskette drive, but check it out. Next, have someone download hard drive diagnostics for the brand of drive in the machine. You could have errors on the drive, and a diagnostic program may locate, repair them. The startup disks, these do a full system restore, reinstall of the operating system? The machine will boot from the first startup disk and begin the reload process?
Sep 12, 2007 | E-Machines etower 400i3 PC Desktop
E-Machines etower 533id PC Desktop Logo
198 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
