Question about Microwave Ovens
Burnt out Microwave light in Kitchenaide KBMC140H Can you explain how to replace?
  • 679 Answers
Step1
Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
Step2
Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
Step3
Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
Step4
Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
Step
5
Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
Step6
Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
Thanks
Posted on Feb 14, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
You are talking about microwave bulb?
  • Rylee Smith
    Rylee Smith Feb 14, 2009
    To replace the bulb remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light.
    Brigadier General:
  • Microwave Ovens Master
  • 3,614 Answers
Hi
can you please be specific on which part is damaged, and has to be change..
thanks
  • 19,396 Answers
You need to remove the covert plate, then you replace the light.
  • Ginko
    Ginko Feb 14, 2009
    Here is the exploded view for your oven:
    Remove plate nr 67 to access the lamp assembly.
My Kitchenaide KEMC378KSS0 Oven Microwave Combo shut down.
Is it possible the cord got knocked loose during the work?
The parts list with exploded views is here.
My site is MicrowaveControl.com so feel free to e-Mail me at pupista@gmail.com for details and free advice.
Sep 27, 2016 | Microwave Ovens
Kitchenaide Superba #4450786A unit turns on but will not heat at any setting. What can I do to fix?
Magnetron needs replaced.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Cheaper to buy a new Microwave oven.
Jul 11, 2014 | KitchenAid KCMS185J Microwave Oven
How to replace light bulb in microwave
Howdy. KitchenAid states that is not a user replaceable part and must be done by a service technician. I have included the link to the manual in the event you have other use for it.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20(Micro)%20-%208300890.pdf
If you have difficulty locating a reliable service technician in your area, we will gladly help locate one.
Thanks for using FixYa.com
Farmerbear
Sep 13, 2010 | KitchenAid KBMC140H Convection Microwave...
Will not turn on says door
There are 3 door switches arond the door that can throw up this error but if the 2 fuses are blown also it will throw up this error. You can ohm out any of the fuses or even the door switches but until you repair them it wont work. I have even found both fuses to be blown. If you are nervous about pulling apart your stove make sure whoever does is very familiar with this line of Kitchenaid. Hopefully this helps.
Jan 30, 2010 | KitchenAid KBMC140H Convection Microwave...
Kitchenaide microwave not heating - no stange noised, everying else seems to be working just no heat
there are few sensors inside that might go bad but do not try to fix it yourself its got 4000v !!! sorry :( your life worth more then this microwave.
Dec 27, 2009 | KitchenAid KCMS185J Microwave Oven
Have a khms155lso microwave (Kitchenaide) and had to replace the door - door arrived today but not sure how to get old door off the hinges to replace.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | KitchenAid Microwave Ovens
Crisp display
yes, it does indicates there is a bigger problem It has run a self- checking program and displayed the error before calling help see in this model page there is a manual of the oven, check last pages if they help u if no still there are instructions what to do and who to connect read it well before calling it will save u more then a couple of $$$ good luck windman
Jan 17, 2006 | KitchenAid KBMC140H Convection Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
