Question about RCA Audio Players & Recorders
RCA RT2770 remote code
I am trying to get this system to work from my digital cable remote but I can't find the code for the RT 2770 all the codes listed in the cable book don't work
5 Suggested Answers
SOURCE: rca universal remote code
hi,
I've lost my code list for my rca universal remote1.gif...my remote is a rca and my tv is rca can you please help me but i can't change my tv so i can watch my movie on my dvd i don't know how to swicthing over to the input so my dvd can play.
Posted on Jan 29, 2008
SOURCE: Bose Cinemate home theatre
My Bose will not turn on. I know I have power because the red led light is on. The remote works fine with my TV. It worked a couple of days ago and now it seems like the signal from the remote is not going through the reciaver.
Posted on Mar 16, 2008
SOURCE: rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
Posted on Jul 02, 2008
SOURCE: RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
there is no "code search" button on the RCR3273???? can anybody help?
Posted on Aug 31, 2008
SOURCE: Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Posted on Sep 21, 2008
Rca rt 2770 programming. My fm radio stations
You can manually program a station by pressing AM/FM to get to the correct radio band. Then tune in a station with the Tuner +/- (the left/right arrow) buttons on the remote. Next press Memory (just below 7) and then a number on the keypad. The number must be entered before the Program Preset number stops blinking. (For FM you can use some 2 digit numbers.) To scan through the stations in memory use the Channel +/- buttons on the remote or the Next/Previous track buttons on the RT2770. You could fill all of the memory slots automatically by pressing and holding the AM/FM button for two seconds. The unit will store the stations that it tunes in in order until the memory slots are full. Note: you do need to have the FM antenna and AM loop antenna connected (and extended for the FM antenna).
Retrevo has the manual for the RCA RT2770 available here: http://www.retrevo.com/support/RCA-RT2770-Home-Theater-Systems-manual/id/2869dj191/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Apr 30, 2014 | Audio Players & Recorders
Rca rt2770 home theater universal remote code.where purchess
If the remote you purchased is universal and made before the RT2770 a code will not be listed in your code book, but you maybe able to call the universal remote manufacturer or visit there website for an updated list.
Oct 30, 2013 | Audio Players & Recorders
Can i hard wire my rt 2770 rca home theater subwoofer to my receiver lost white plug that plugs into receiver and can't find a new one?
I have one if you still need it. Hooked my sub up to a different receiver and cut that end off to hard wire it. It has about a foot of wire and the white plug on the end that goes into the receiver.
May 11, 2012 | RCA home theater system RT2770 User Manual
Greetings, i'm looking for a rca rt2770 remote or replacement. any ideas? can i change the speaker levels without it? thanks
You can purchase one here http://www.replacementremotes.com/RCA/Buy-RT2760-RCR192AB1-273471-Home-Theater-system-Remote-Control.html
Sep 23, 2011 | RCA RT2770 Theater System
Blowed up in my RCA RT 2770 a resister and I need the number
Contact customer service, http://www.1800customersupport.com/rca
Feb 22, 2010 | RCA RT2770 Theater System
I have a RCA RT 2770 receiver and the usb port does not detect any devices. It does have power as I have connected an IPod and it charges via the usb port. It just does not detect the mp3 player, IPod or...
look here
http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
USB Device Playback Features
(Only support MP3/WMA file)
1. Press USB on front panel or remote control
to select USB mode.
2. Press to start playback or press to
pause playback.
3. Press to end playback.
4. Press CH+/- on the remote control or /
on the front panel to skip to the previous or
next file.
5. Press REPEAT on the remote control to select
repeat mode. (REPEAT ONE, REPEAT FOLDER,
REPEAT ALL, REPEAT OFF)
6. Press RANDOM on the remote control to
select random play mode. (RANDOM ON,
RANDOM OFF)
7. Press INTRO on the remote control to turn
on/off intro mode. The unit will play the first
ten seconds of each track on the USB device.
8. Press DISPLAY on the remote control to
select among mp3/WMA ID3 information,
elapsed time,current play Folder and Track
number and Play Mode.
Dec 10, 2009 | Audio Players & Recorders
Help
I cannot find any way of doing this from looking at either manual for the remote or the theater. It is my understanding that RCA makes "smart remotes" that supposedly recognize and control other RCA components, but I have no idea how this works. My suggestion is to read the manuals and maybe find something I didn't or contact RCA Customer Service.
Oct 09, 2009 | RCA RT2770 Theater System
I have a RCA RT2870A that i need a manual or help hook it up to TV and DCD
This is the manual for the 2770 from RCA.com http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
If it has the same inputs as yours, you need an "optical" cable that will go from the TV "output" to the RCA system "optical input" and a "Coaxial Digital" cable from your DVD player to the "Coaxial Digital input of the receiver. Not knowing what kind of TV you are hooking this up to... If it's and LCD,Plasma, or Digital TV, it will have an optical audio out. if it's not one of these, post the model number of your TV & I'll check it. If you are using Cable TV/Satellite or FIOS, Great! then you can run the optical cable from the back of the cable box to the receiver. If you need any more help, just post a comment and I can help you some more.
Jun 23, 2009 | RCA RT2300 System
Apr 05, 2008 | Audio Players & Recorders
188 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
