Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Whirlpool GU3200XTP dishwasher - No spray on upper rack
The upper rack does not appear to be getting spray. Upper spray arm rotates freely and nozzles appear clear. Also dishes and cutlery in the the lower rack are not cleaned properly.
  • Anonymous Mar 13, 2014
    Have deep cleaned the dishwasher, but the dishes are not clean, especially the cutlery tray.
  • 10,865 Answers
Sounds like the hose assembly that attaches to the rear of the upper rack has come undone. just pull out the upper rack and reconnect it.
please rate my answer as a fixya! thanks.
Posted on Feb 14, 2009
Top dish rack dishes don't get clean model 8575637
Most dishwashers have a rotating spray bar underneath the upper rack. Over time bits of food can clog up the holes and then dishes won't get clean in the upper rack. Check to make sure all the holes in the spray bar are clear and that it is rotating freely.
Mar 22, 2017 | Dishwashers
Why doesn't upper spray arm function properly?
A couple of scenarios could cause this problem but the simplest might be the way the dishwasher is loaded. The upper spray arm rotates when water is pumped through the vertical supply tube and into the arm. Make sure that you are not loading the lower rack with items that interfere with the rotation of the upper arm rotor. It might also be a good idea to verify that the feed tube that goes to the spray arm is securely connected to the vertical supply tube.
Dec 02, 2015 | Kenmore Dishwashers
Not cleaning dishes
Good Morning Lynn, thank you for your post!
I understand your dishwasher is not cleaning properly. Will the spray arm rotate freely or is it damaged? If so, you might have to remove and replace the spray arm assemblies. The top spray arm typically starts to function when the unit is in rinse or wash cycle. If for some reason the top rack is not getting clean, there is a possibility that it is not working properly. The top spray arm is either blocked by pots/pans or not enough water pressure is being pump meaning that the flow of water is not making it to the upper spray arm. If you tap the delivery tube that feeds this nozzle and the water pressure jumps immediately, then the problem may lie with a faulty pump or impeller. Should all basic troubleshooting measures fail contact a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
Dec 15, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Upper spray arm
Hello Alan - Will the spray arm rotate freely or is it damaged? If so, you might have to remove and replace the spray arm assemblies. The top spray arm typically starts to function when the unit is in rinse or wash cycle. If for some reason the top rack is not getting clean, there is a possibility that it is not working properly. The top spray arm is either blocked by pots/pans or not enough water pressure is being pump meaning that the flow of water is not making it to the upper spray arm. If you tap the delivery tube that feeds this nozzle and the water pressure jumps immediately, then the problem may lie with a faulty pump or impeller. Should all basic troubleshooting measures fail contact a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
Jun 24, 2013 | Frigidaire 24 in. FDB126RB Built-in...
GLD5900N00WW
You need to remove the top wash arm and check for any blockages in the holes, clean them out and make sure the arm spins freely.
Mar 06, 2012 | Dishwashers
Hi, the dishwashers top rack dishes are not being cleaned.. help?
sounds like the upper spinning arm is not turning check to see if it is clogged at the nozzles if so take off and clean particles out also check bottom ofjet that spray soap up to upper spinner and see that is not blocked
Nov 12, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
I have an LG model LG8812st dishwasher and the spray nozzle under the top rack does not rotate. It turns freely by hand but it appears there is no water geting to it through the connection on the rear...
Either the pump is not able to pump due to clogged pump or there is not enough water in the tub after filling to get up to the upper spray arm.
Sep 05, 2009 | Dishwashers
Will not clean dishes on the upper rack
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Jun 16, 2009 | KitchenAid KUDR01TJ Dishwasher
Upper spray arm is not turning round even though water is coming through. We have checked the internal system for blockages and the machine is filling / draining as normal. When a full programme is run,...
I found the problem to be neither blockages of the upper arm or roof spray arm or the upper basket arm hitting the the back of the dishwasher. the problem was that the pump inlet where the food scraps are macerated was blocked with all manner of gunge including small chicken bones plastic and other detritus. Removal of the macerator housing under the upper filter housing using 2 different sizes of torx driver easily fixed the problem. Probably why the upper dish rack cleaning degraded overtime, Directly proportional to the amount of detritus blocking the intake screen behind the macerator.17a8801.jpgb9e8fa8.jpg789f2b8.jpgfb7a626.jpgator. See pics
Jul 13, 2008 | Dishwashers
Broken nozzle and upper spray arm
Thanks for the help. Like the other guy said the "ninga star" thing unscrews and using the plastic part inside I just pop the spray arm back on. Screw it back and it works again.
Mar 15, 2008 | Frigidaire GLD2445RF Built-in Dishwasher
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
542 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
