Question about JVC AV-48P575 48" Rear Projection HDTV-Ready Television
No sound JVC tv Model # AV48P575
No sound on tv....when I go to the menu option I can scroll down all options invloving color etc, but when it comes to the audio menu, it seems ;locked"..it stays muted gray and I cannot scroll down over bass/ treble etc...It goes right to the reset option, but i can not do anything with this choice...I also no longer have the original remote
jvc Model # AV48P575
    President:
  • JVC Master
  • 1,779 Answers
You will have to use the control buttons on the front and navigate to personal pref. and restore that to normal. You may have to re do the initial set up. Be patient and give a whirl. Let me know......
Posted on Feb 14, 2009
Is my 2005 jvc av48p575 capable of receiving digitally formatted television stations or do I need a digital converter box?
If your TV displays digital channels, i.e., 10.1, 50.2, etc., you do not need an A/D converter.
Feb 15, 2015 | JVC Televison & Video
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
There is no sound on the tv. how do i fix it?
Hello, try pressing menu, then select the audio/sound option, this will give you the scroll down list for sound mode, reset,treble etc. punch in reset(factory settings) If this doesn't do it keep scrolling down to speaker and select "on" If this does not work you'll need to have the TV inspected, but before you do make sure the cable/sat feed is not muted or lost it's sound(try it on another TV).
Mar 24, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
How to get TV off game mode without remote (not a
is there a TV/Video or menu button on the front of the tv? if so try the tv/video button, that should scroll through the the components you have on your tv. dvd, game cable etc. If no tv/video, hit the menu button and then use either channel up/down or volume up/down to scroll through your component options.
Dec 27, 2009 | Sylvania 6427TE 27" TV
No color picture on Toshiba CF36G40
You need to go to the menu screen where the contrass, color etc are located. Scroll each option and one of them will add the color, one of them is probably at 0 so you need to ensure that it's added
Feb 15, 2009 | Toshiba CF36G40 36" TV
No sound and sound menu stays muted so cant adjust
Have you totally unplugged the TV?
If not do so for 10 minutes and see if it resets.
Try to find a remote that goes with TV>
Mastersage.
P.s. Make sure you do not have the saftey lock on. You can adjust the control;s from built in adjustments.
Mastersage!
Feb 14, 2009 | JVC AV-48P575 48" Rear Projection...
The sound went out on my jvc hidef tv
Reset- resets all picture adjustments (tint, color, picture, bright, detail, color temperature, dig.
noise clear, Color Management and Dynamic Gamma) at once to the default settings.
Press the MENU button
arrow To RESET
arrow To enter
The onscreen menu disappears for a moment,
and then the settings are reset to the default
setting for all the picture/audio adjustments.
Press the MENU button when finished
Here is a LINK to download your owners manual
Feb 12, 2009 | JVC HD-52G786 52" Rear Projection HDTV
I have picture but no sound
go into the audio menue to turn speakers back on
Dec 27, 2007 | JVC AV-56WP30 56" Rear Projection...
Jvc tv
Before confirm the picture faulty go and the select the blueback option ON in menu option. Disconnect the cable signal and check the tv displays bluescreen. If it is there picture tube will ok, fault in C board. May be dry contact in blue output section the picture tube conducts heavily the respective color.
Sep 14, 2007 | JVC AV32F577 32" TV
JVC AV-48P575 48" Rear Projection HDTV-Ready Television Logo
166 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
