Question about Uniden BC92XLT Handheld Scanner
CB92XLT hand held scanner keeps hissing and won't scan
Scanner keeps hissing and I cannot adjust the squelch to get it to stop therefore it won't scan. I can manualy hit the scan button and it will change to a different channel but keeps hissing. Any ideas?
    Problem Solver:
  • 6 Answers
Got the same issue man, you fix it? im checking mine over now, will let you know if i fix it. if you still need it.
Posted on Feb 27, 2011
Turn the squelch knob to the middle of the min. and max.
Posted on Feb 16, 2009
What did you mean by change the squelch?
The squelch control gets rid of the hissing on a blank channel. Finda blank channel, turn up the squelch control until the hissing stops. The scanner should then scan the channels and stop on a busy one.
Jul 12, 2014 | Uniden Bearcat Scanner Bc355c 800 Mhz...
I have a bc60xlt andno matter how i turn the squelch i get the same hiss what happened
The Bearcat Scanner is neat hand held scanner, Is the scanner programed? Depress the WX for weather and see if the weather channel is available. The squelch knob should be turned clockwise and the noise level should decrease (actually you are decreasing the allowable signals to be received). If you get no response from a know frequency, then the squelch pot may need cleaning or replacement may be in order.....Cost for repair at service shop may not be feasible.
May 26, 2014 | Uniden BC60XLT Handheld Scanner
I have tried to adjust my squelch but all i hear is loud static in between transmissions
  • Hi, I can help.
  • If your getting transmissions then the receive is working.If your squelch is not adjusting out then it is possible your antenna, or the connector, is not working right. Hand held scanner antennas are the same across the board as for frequency use. The connector your antenna uses is a standard BNC connector. So your antenna is really universal which mean you don't have to go to Uniden and pay top dollar for their antenna.
  • Now it is possible the squelch knob is giving you trouble. but I would see if you can borrow an antenna just to try from anyone you know that has a hand held scanner. As long as their scanner works well with that antenna it should on yours too. If it don't then check the connector for the antenna on the scanner and make sure it is not loose. You can open the scanner and just eyeball the connections and make sure no soldier joints are not cold.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 17, 2011 | Uniden BC72XLT Handheld Scanner
Can't break squelch ? Have Uniden Bearcat hand held scanning radi
Look at the squelch knob. If it is turned fully counterclockwise, it is in "Auto". Turn the knob clockwise to enter the manual mode and adjust the range untill static is heard. Reverse direction until the static is no longer heard.
Jul 17, 2010 | Uniden BC248CLT Base Scanner
Hi um i have this scanner and the frequencie come in but it comes in and out like the antana dosint work
Adjust the squelch until you hear a hissing sound, and trun the knob back slowly until the hissing stops.
Jun 12, 2010 | Uniden BC60XLT-1 Handheld Scanner
New BC355C put 7 channels in,but only will stop on 2
1. Be sure sure that your squelch is adjusted properly. While scanning, turn the SQUELCH control down slowly until scanning stops and you hear a hissing sound. Then slowly turn the control back up until scanning resumes. That will set a proper threshold level for the frequencies you're monitoring.
2. Be sure that signals are not blocked in your area. Topography plays a large part in VHF and UHF radio reception. A hill, a tall building, even a thick grove of trees can prevent a signal from reaching your antenna.
3. It's possible that there was just no traffic on the five freqs while you were listening.
4. Be sure that the frequencies you've programmed are assigned in your area.
5. For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
BillB
Jan 26, 2010 | Uniden BC350C Base Scanner
I cant get my 350a to lock in on a channel when its scanning in the private mold.it will try sometimes but wont hold them. I can push the hold button and hear crystal clear in the private mold. help...
If you haven't already done so, while scanning in the PRIVATE mode, turn the SQUELCH control down slowly until scanning stops and you hear a hissing noise. Then turn the SQUELCH up slowly until scanning resumes. This should set the threshold so that the scanner will stop on an active frequency.
BillB
Jan 18, 2010 | Uniden BC350 Base Scanner
How to progam a bearcat police scaner
To program known frequencies into your BC370CRS:
- Slide the MODE switch to the "Scanner" position.
- Press and hold the POWER button momentarily to power the scanner ON.
- Turn the SQUELCH knob slowly to the left until scanning stops and you hear a hissing noise.
- Turn the Volume level down to a comfortable level.
- Turn the SQUELCH knob to the right - slowly, until scanning resumes.
- Press HOLD.
- Press E (PGM).
- Press 0, 1.
- Press HOLD.
- Enter your first frequency, including the decimal point (EX: 158.075).
- Press E (PGM).
You've just programmed channel 01. To contimue programming, press the up arrow to advance to channel 02, press HOLD, enter your frequency, etc.
When you're finished programming, press the SCAN key.
Need the manual for your scanner? You can download and print it here:
http://www.uniden.com/pdf/BC370CRSom.pdf
Please contact me if you have any further scanner questions.
BillB
Jan 08, 2010 | Uniden BC370CRS Base Scanner
I don't have the manual for my Uniden Bearcat BC 855 scanner.
You can download/print the complete manual for your scanner by following the link below. It's a free download, and it provides detailed programming instructions. If you're programming a channel that is "empty" (showing 000.0000) just enter your frequency. Empty channels automatically show LOCKOUT but it clears with programming. The squelch setting will vary according to the strength of the signals you receive. Once you start scanning, turn the squelch down until scanning stops and you hear a hissing sound, then turn the control up slowly until scanning resumes.
Dec 30, 2009 | Uniden BC248CLT Base Scanner
Uniden BC92XLT Handheld Scanner Logo
174 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
