Question about RCA HD52W56 52" Rear Projection HDTV
Press Pwer Tv sounds like its starting turns off then back on
When i press the power button on my tv it will act like its turning on then shut down then back on and so on until i unplug it
  • RCA Master
  • 5,138 Answers
CK capacitors cp114,120,150f any of them are puffed up on top then replace all 3 capacitors 2200uf 16v and two 220uf 35v. resolder all pins on FBT flyback transfomer.
Posted on Feb 15, 2009
I have a Samsung DLP HLS 5086 W that is shutting down after a couple of minutes. The color wheel and lamp were both replaced a little over a year ago. The lamp is a Phillips, and the color wheel is OEM. I...
Hope this helps:
Resetting the counter Once you have installed your OEM replacement lamp, resetting the counter is a very simple procedure:
• Begin with the TV powered off.
• Point your remote towards your TV.
• Press:
• Menu + 1 + 8 + 2 + Power.
• Your TV set should now say "Loading Factory".
• Browse down to "Option" then press Enter (or the right cursor button).
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you're having difficulty with the ENTER button.
Resetting Your Samsung DLP Lamp Hour Meter Counter or Lamp Timer DLP Lamp...
Jan 14, 2015 | Samsung Televison & Video
When I turn off my television my vip722k powers off
There should be 2 buttons on the remote control that turn on power. One should be for all devices controlled by it and the other for devices you press first and then press that power button.
Jan 12, 2013 | Televison & Video
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Remote codes for the 22LV506 for a dish network remote please. none of the provided codes for this tv work. Thanks, Frank
You can power scan any dish network remote for the correct code by pressing and holding down the tv button(clear or gray button at the top of the remote) until the lights all light up, release the tv button. Press the larger red power button (not the red tv button) release button then press the channel up button repeatly givng time for tv to shut off. Once tv shuts off press pound key and red tv button to turn tv back on, Press sat key to go back to satellite mode.
Jun 19, 2010 | Toshiba 22LV506 21.9 in. LCD HDTV/DVD...
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
Programming my remote to control the sound on my TV
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Jul 24, 2008 | DISH Network IR Remote Control
Dish network remote
i would suggest trying power scan again...
3)press pound sign
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
Echostar IR remote (Dish)
to set remote to tv
3)press pound sign
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
HL-r6167w wont start up (HELP)
it sound like the color wheel is bad
Nov 26, 2007 | Samsung HL-R6167W 61" HDTV
RCA HD52W56 52" Rear Projection HDTV Logo
132 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
