Question about JVC AV-48P575 48" Rear Projection HDTV-Ready Television
No sound and sound menu stays muted so cant adjust
The sound on this TV went out...and when I go to the menu screen I can scroll down all menus to adjust color etc, but when it comes to the sound adjustment menu, it seems to be locked..it stays a muted gray color and i cant scroll down over bass/treble etc. I do not have the original remote. It goes right to the "reset" bar, but I can not do anything
    Scholar:
  • 164 Answers
Have you totally unplugged the TV?
If not do so for 10 minutes and see if it resets.
Try to find a remote that goes with TV>
Mastersage.
P.s. Make sure you do not have the saftey lock on. You can adjust the control;s from built in adjustments.
Mastersage!
Posted on Feb 18, 2009
Toshiba 72hm195.how do i enter service menu
With the set ON, press MUTE once remote, then press MUTE again and hold in down while pressing MENU on the TV The letter S will appear on the screen to show that the set is in the Service mode To select the adjustment that you want to change press CH+ or CH - Press VOL+ or VOL- to adjust
Sep 29, 2013 | Toshiba 56HM195 56" Projection HDTV
Our replacement samsung dlp tv lamp doesn't give us a full screen picture on any stations other than the High Definition stations, how do we fix this?
The high def stations are full screen as they are transmitted in a 16:9 ratio which is full screen. However the non HD channels are transmitted in a 4:3 ratio which is square and not full screen. Usually this can be rectifyed by putting your tv in 16:9 mode through it's menu's. You can also adjust this setting through your cable box if you are using one.
Hope this helps
Jun 27, 2008 | Samsung Televison & Video
Found a way to get into the adjusment menu but
Hold and press ACTION and POWER on the front of the set for at least 5 seconds together and then release both buttons--should take it out of the Chk mode.
if this was helpful give me a vote here
Aug 18, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Toshiba 57H82 convergence problems. TouchFocus
See my solution <http://www.fixya.com/support/t2795690-convergence_off_blue_line_only_vertical>.
You need to get to the service menu--it's been 4 years so go to AVSforum.com to turn off the different guns and get the better pattern.
At your risk: To get into Service mode:
1. Turn your TV on. 2. For X81 or earlier series: Press MUTE on your remote and release. 2. For H80/H81/HX81 series: Press MUTE on your remote and release two times ("Mute" on-screen) 3. Press down MUTE on your remote again and hold. While holding, press the MENU button on your TV set's front panel. 4. Release both buttons. 5. An "S" should appear on your screen. Press MENU again on your TV. 6. Now you're in service mode. Channel Up/Dn - Scrolls through Parameters and Volume Up/Dn - Changes Parameter Value
To get into convergence mode:
Get into Service mode, then Hit '7' to bring up the convergence grid. Buttons 100, 0, and ENT control which gun you want to turn off (if you want to align the red to the green without seeing the blue gun and other variations). 2=up, 8=down, 4=left, 6=right, 3=change gun to converge, 5=converge that point. To exit convergence mode you press 7 once and your screen should look like it's imploding then return to normal and then you press 7 to get back into regular service mode.
I have more info found on the board. -Ken
Jul 31, 2009 | Toshiba 57H82 57" Rear Projection...
No sound JVC tv Model # AV48P575
You will have to use the control buttons on the front and navigate to personal pref. and restore that to normal. You may have to re do the initial set up. Be patient and give a whirl. Let me know......
Feb 14, 2009 | JVC AV-48P575 48" Rear Projection...
Cant see top 2" of program
Try going to the service mode. I think it goes like this. Press menu, and hold it. Then press volume up and volume down at the same time for 8 seconds. Then you should be able to go to service mode. scroll down till you find the adjustment for vertical size, the top part. If the service mode proceedure I gave you is wrong, You can try asking someone else here if they know how to go into service mode for your particular model.
Jan 04, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Samsung:pcl4515r
You may still one more resistor opened , samsung most of the time its 2 low ohms but can be 3 it will be same value as other 2. I think they are 2.7ohms or 3.9 How to Enter Service Menu for convergence Turn TV off Press Mute 1-8-2-power now you should be in convergence use vol- and vol+ to select an item Use mute and menu to adjust when done Press ADD to save adjustments made.
Dec 12, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
Need to reset lamp life indicator on lg rear projection tv model no 525sz812-tb
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) To Check if it was a success
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 21, 2008 | LG Televison & Video
Front buttens locked and no remote rca d52w19byx1 itc222
when using your remote once you get to where you want to Go to adjust press channel up & down buttons this will let you scroll up and down and then use vol- vol+ to make adjustments.use buttons on front of tv.ThankYou for using FixYa.Have a Nice Day.
Feb 05, 2008 | RCA D52W19 52" Rear Projection Television
JVC AV-48P575 48" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
