Question about Whirlpool GH7145XF Microwave Oven
Frigidaire plmv169dcd not venting properly. Filters are clean.
I want know how to improve its venting efficiency. Filters are clean, but the unit still does not appear to pull properly when several pots are on the cooktop.
  • Whirlpool Master
  • 9,098 Answers
If it's equipped with a charcoal filter, that needs to be changed (not cleaned) about every 6-12 months, depending on use.
I would also very the installation and venting set up found in the installation instructions.
You can download Electrolux/Frigidaire owner's manuals and installation instructions here.
If all that is proper, then I would suspect an obstruction such as an animal nest in the vent outlet or in the duct work.
Posted on Feb 15, 2009
How do i get the air vent cover off, so I can clean grease from the top.
Good Afternoon Friend,
I understand you are trying to the air vent cover off your Frigidaire microwave, model# PLMV169DC, so you are able to clean the grease from underneath the top cover. Please follow these instructions:
1. Disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the louver mounting screws.
3. Pull the louver away from the unit.
4. Change the charcoal filter.
5. Carefully push the louver back into place and replace the screws removed in step 2.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire PLMV169DC Microwave Oven
How to repair a Frigidaire PLMV169DCD rangetop microwave oven that no longer heats food
I see you want to know how to repair your Frigidaire microwave, model# PLMV169DCD. Repairs on microwaves are typically not a do it yourself repair. I suggest contacting your local authorized technician for further assistance. They have been trained specifically on your appliance and will know exactly how to repair your microwave. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire Microwave Ovens
Control Board wiring
How old is the unit. normally there is a tech mini manual of one or more pages inside the control panel or you might look in the upper vent area. this wiring / schematic would list the wiring positions of the relays you mentioned.
Mar 28, 2012 | Microwave Ovens
Determine venting requirements
When you initially unpackage the microwave oven it is already set up for RECIRCULATION mode (which is VENTLESS). However, since the unit recirculates air rather than exhausting it out through the wall or roof, it usually uses a couple of small charcoal filters behind the upper grille and mesh filters on the underside that have to be changed or cleaned periodically. These filters will accumulate grease and dirt over time and should be periodically checked in order to maintain proper ventilation and air flow. Information pertaining to the location and care of the filters is explained on Page 4 of your Owner's Manual.
NOTE: If you wish to convert to a VENTED system, the instructions are listed on Page 4 of the Installation Guide.
If you do not have either manual you can obtain copies at managemylife.com. Just type in your model number as "GMH3174XVB" and you will find the manuals listed in a .pdf (Adobe) format that can be printed or downloaded for FREE.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 25, 2010 | Microwave Ovens
Plmv169dcd
Similair problem, but no spark issue, just stopped working. No power at all...nothing. The unit is dead. What could be the problem?
Jul 22, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidaire micro plmv169dcd not working
test it with a meter it has a small wire inside and, sometimes can not be visually checked
May 28, 2009 | Frigidaire PLMV169DC Microwave Oven
Control pad does not repond
hi
i think the timer has to be reset,,and make a hard reset..
than k you............
Mar 06, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidere PLMV169DCD
You most likely had a power surge and blew a fuse. First unplug the unit,then remove the top grill. There will either be one screw on top of the control pad or 2 on the left side. open the control panel and look for a fuse that has a ceramic center and replace it with a 20 amp one. You can find these at the hardware store
Jan 31, 2009 | Frigidaire PLMV169DC Microwave Oven
Hi There, I have a Frigidaire PLMV169DCD. the problem is I have the windows showing push clear to enter time, The only 2 buttons working are the fan and light. everything else is not working. I tried to...
Chances are it's the keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 02, 2008 | Frigidaire PLMV169DC Microwave Oven
Whirlpool GH7145XF Microwave Oven Logo
471 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
