Question about Betty Crocker BCF1690 Bread Maker
The bread only rises about half way.
This bread maker has worked well for about 10 years. It is only used one or two times a year.The last time we used it the bread would only rise about half way. We got new ingredients and had the same problem again. We used the same receipe we have always used. It doesn't seem to mix as vigorously as it did. I took the bottom of the bread maker and checked the belt. It is a little loose but doesn't slip. Does any one have any idea what can be wrong?
  • 1 more comment
  • gnwilloughby Feb 17, 2009
    Would this cause the bread maker to mix less vigorously. It used to move around on the counter when it mixed and make more noise. It does bake the bread. Could it bake the bread and still not turn the heater when the bread was riseing?
  • Anonymous Feb 24, 2009
    my mod 1691 mixes the dought and will go into kneeing, it just keeps on kneeing and will not go beyond that stage.
  • scottm5462 Feb 25, 2009
    For me, the bread still rises, but it clearly isn't getting kneaded as much as it should and consequently doesn't rise as much as it should.  I can tell that there is something wrong with the shaft that holds the blade--it now slips around and can be easily removed from the pan. But I can't tell what's wrong with the shaft assembly.
    I'm actually using a Betty Crocker BC-1699, but I'm pretty sure they are quite similar.
  • 134 Answers
After its mixed the ingredients and before it cooks, it should sit for a while to allow the mix to rise. Check that the heater is on in this period, otherwise, if its cold, it wont rise
Posted on Feb 14, 2009
  • royzee Feb 17, 2009
    No, it should certainly mix the same as it always has.
    The "preheat" for the rising uis a vseperate stage to the cooking. After its mixed and it sits there for 30 minutes or so, just check that its warm and the dough should rise.
    If it does, and its not mixing as strongly as it did, then try chabging the belt
    All the best
The bread doesn't rise properly, it sort of sinks in the middle. This is the same recipe we've used for years successfully. Could the machine just be broken?
Is this the same machine you have been using all this time? Or, is this an old recipe that worked in your previous machine but doesn't work in your Cuisinart? If you have moved from one location such as Florida to Colorado, elevation changes like that can make a difference in bread rising properly. If nothing has changed and now your bread doesn't rise properly then try using 1 tablespoon less liquid. If that doesn't work try 2 tablespoons less liquid and 1/2 teaspoon extra yeast.
Jun 15, 2014 | Cuisinart CBK-200 Bread Maker
Bread does not rise
Make sure you are using the correct type of yeast. The old style active dry yeast is not as good. I recommend that you try Red Star Quick Rise Instant Dry yeast. Also be sure to store the yeast in the refrigerator. And, if you are not using a mix, try King Arthur Flour, it costs a bit more, but their tighter standards means you get more consistent results. They also have bakers who will answer your questions for free at 802-649-3717.
Nov 16, 2012 | Sunbeam 5891 Bread Maker
Can only use programmes which allow changing the crust setting to 'dark' other programmes half bake the bread.
This is a tough one. One thing you might try until you can replace your machine is to look in your manual and look at the page that shows the cycles of the program you chose. I wonder if you could shut the machine down after the last rise cycle next time,,,,,the,,,,. Push the Stop button until it beeps.... then unplug your machine and reprogram your breadmaker on the "Bake" program and set the time by pushing the timer advance button in 10 minute increments to the equivalent of the last bake cycle of your original program for light crust bread? That just might work!
Oct 22, 2010 | Panasonic Kitchen Appliances - Others
Lately, every time I bake bread (using same recipe that always worked well in the past) I end up with a loaf that is collapsed in the middle with top half either missing or looking half baked. The machine...
It could be that the belt is worn and not kneading the dough properly. Either that or the paddle is sticking (see if you can spin it by hand), or the heating element is not getting hot enough. Hank
Jan 18, 2010 | Kitchen Appliances - Others
Frequently the bread does not rise correctly when doing "fast" mode.Should the unit be heating during the rise cycle?
Bread not rising correctly is complicated since there are so many factors involved more than just proofing temperature. You should hear a short click once in a while as it cycles the heater on for just a second at a time. You won't notice any considerable heat since too much heat will kill the yeast. Bread not rising correctly is normally due to the gluten not being developed in the bread or the flour was poor quality without much gluten to begin with. You can try adding some "Vital Wheat Gluten" to each batch to help and at the same time adjusting the yeast up by a half teaspoon at a time. Also keep in mind that the salt you add to the dough will ****** the yeast. Try and limit the salt to a teaspoon per loaf. Too little salt and the taste of the bread will go bland on you. Another aid to rising is to add some Diastatic Malt Powder to assit in the rise. And lastly, remember that you whole wheat flour will never rise as high as white flour.
Nov 20, 2009 | Breadman TR875 Bread Maker
Not warming up for bread to rise
sounds like a problem with the control board not bringing the heat on to proof the dough
im not sure about the brand you have, but they normally cost more to fix then replace
May 05, 2009 | Kitchen Appliances - Others
Bread does not rise
Sugar is the component yeast needs to activate but I don't believe salt has much if any effect.
Check the machine's temperature during the time it should rise; it should be just noticeably warm. If it isn't, then the controller isn't cycling the heating element as it should.
Mar 27, 2009 | Sunbeam 5891 Bread Maker
I need to fix the rool of the pan Oster 5838 Bread machine
Try this link, ther is a bread maker for sale used exellent shape.
Also try and contact customer service.
Feb 15, 2008 | Oster 5838 ExpressBake Bread Maker
Bread won't rise
We have owned a Panasonic bread maker for ten years and gets used twice a week to make bread using "spelt " flour.About three years ago the bread maker was producing flat loaves,and was very heavy.We contacted bread making company called "Simply No Knead"and asked for there advise,as we were following the same recipe and method for around six years. They suggested that we add a little more water,and this would fix the problem.We tried this and the bread still failed to rise,so we rang them again .This time they said that we need a new bearing in the bread maker and that would fix it.We did this at a cost of $40 and still no good.This happened over a period of several months.We suggested to them that there must be something wrong with the flour,which they denied.After checking the labels on the packaging we noticed that they were using flour from another country [ I think it was Hungary ],because they had run out of suppies from Australian wheat produces.
The flour was far to old,and bread won't rise if the flour is to old. As soon as they started using Australian produced flour again the bread improved dramatically.
Hope this is helpful to you
Dec 11, 2007 | Breadman TR875 Bread Maker
Betty Crocker BCF1690 Bread Maker Logo
249 people viewed this question
Top Betty Crocker Kitchen Appliances - Others Experts
Nancy Berhorst
Level 1 Expert
Rick Ostrowski
Are you a Betty Crocker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
