Question about Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw
Husqvarna 345 power loss and vibrates
The saw starts and runs fine. All of a sudden it started to vibrate badly. As long as you cut on the back side of the chain, it cuts good. If you cut on the top side, it has a lot of power loss. All of this just started.
    President:
  • 1,902 Answers
Replace the bar. Your bar has gone bad and that is why you are losing power. Bars are made by the chain saws to be completely oiled at all times. When the bar does not get oil the bar will start to warp and that is what will cause you lack of power when trying to due a top cut
Posted on Feb 16, 2009
I have a husqvarna 345 run for a few cuts then stops.
either blocked fuel filter in the fuel tank ( hook out and replace ) or the fuel tank breather is blocked thus causing a vacume in the tank, to prove this, when the saw starts to die slacken off the filler cap, this will allow air into the tank and it should pick up again, the breather is pressed into the tank on the r/h side rear.
Sep 19, 2012 | Husqvarna Forest & Garden No.967012396 345...
I have a Husqvarna YTH2348 that I bought from Lowe's last summer. As I was mowing today it suddenly started to vibrate excessively. I believe the problem is in the transaxle. When the brake is engaged...
There are usually one or two idler pulleys on the belt that runs from the engine to the transmission. Check those, more than likely one has gone bad. the should spin freely with the brake engaged, and the should not wobble.
Sep 11, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
CTH 171 Mower starts and runs fine but lacks power to climb even gentle slopes whether or not it is cutting.
The mover has great vibration as all mowers do. That is why the valves are recommended to be regapped at every 250 hours of running time. If not checked the engine will run although will be reduced in power going up a grade. Eventually it will not start so easily if not serviced soon
Jul 09, 2011 | Husqvarna Garden
Have a Husky 254xp and I have to consantly readjust h&s needle valves back to their reccomened settings even after 1or 2hrs use. Suggestions? Brian
When you say re adjust back to basic settings, are they actually vibratinh out? it maybe the springs have become weak and allowing them to move due to the vibration of the saw.
May 14, 2011 | Husqvarna Forest & Garden No.967012396 345...
Optoma DV10 loud vibration and odd colours
check the colour glass wheel is shattered with a piece of glass still stack to the wheel. it not even thats why it vibrates
Aug 17, 2009 | Optoma MovieTime DV10 DLP Projector
93 camaro 3.4 sudden jerking, running rough
Sounds like a good tune-up and add a cleaner to your gas to keep the injectors clean.It will also help you on fuel.Camaro's vibrate when they go through transitions between gears.You should feel a pull to your back when accelerating.As you stated,"Ride it out and it will "come back" For a while.."If you are talking once you get to top speed, ease off the throttle and the power will come back to you.Also, make sure you keep a fresh oil change.Camaro's are high performance vehicles, so they will burn oil quicker. Have a nice day James
Jun 25, 2009 | 1994 Chevrolet Camaro
Husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
Jun 11, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna ranger 55 chainsaw starts but quits
I too have a rancher 55 and had what sounds like the same problem this week. It would start fine but run for only a few seconds at a time. I took it all apart today and found the problem - a cracked fuel line. In the places where I could see the hose it looked fine, but it wasn't until I removed the fuel tank that I found the crack...right where it exits the tank and then goes thru the housing above it. You don't need to remove the tank to replace the hose but it is easier that way. You do have to push it thru a grommet at the top of the tank. I read some other posts about checking the tank vent to see that it's not plugged up. Mine was ok so I knew it had to be something else. The vent is in a hole about the size of a pencil and is recessed about an inch into the tank on the upper right side. Its partially covered by a plastic cap that's part of the vibration damper, which can be removed to gain access to the vent. The vent tube can then be pushed out from inside the tank with the use of long needle nose pliers, but be gentle. I just loosened it then pushed it out with a finger. I put it all back together with a new hose and its running like new again!
May 28, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Bad Clutch??
Hi
Before other checking change the spring of the clutch(2).
best regards savumihai71
Feb 14, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Logo
297 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
