Question about Vizio L32 32 in. LCD HDTV
Visio 32L color goes bad with ghost images after about 5 minutes.
We have had no problems with our tv since we purchased it a bit over a year ago. Recently after it is on for a while the picture goes bad with weird color and ghost images. If you shut it off for about 2-3 minutes and turn it back on it will work fine for about the same time period and then go bad again. If you shut if off for only a minute it will not return to a good image. Almost like the power has to bleed off everything before it works right again. Any ideas?
  • Anonymous Mar 03, 2009
    my first vizio 32 in whent to those funny colors, we sent it back and they sent a new one and its started to do the same thing
  • 718 Answers
This sounds like one of the two things that destroys electronics. Heat. You can try this. Place a fan blowing into the vents of the set before you turn on the set. See if the set run longer before the problem occurs.
You may have a marginal part or bad connector/connection.
Posted on Feb 19, 2009
I have sony bravia KDL-40BX420 TV ,purchased 03 years back.recently got a problem with pictures & colour.It shows pictures with shadow & colours are blured.please give your feedback
I would check the menu settings and reset everything to default. if there are calibration tests in the menu, use them. Try more than one source for video.
May 22, 2014 | Sony BRAVIA KDL-40BX420 40" 1080p 1920 x...
What would effect the picture quality the color wheel or lamp?
The color wheel is your suspect.......usually whines a bit
when bad. In a quiet room, you can hear it when the TV is powered on or off. It spins at 9,000 rpm ( wears out the bearing).
The lamp will not exhibit those symptoms....
Apr 26, 2014 | Televison & Video
Viewsonic N3252W picture ok but no sound
Download the repair book to this TV by net. It will have all details.
May 23, 2012 | ViewSonic N3252w 32 in. LCD Television
TV picture goes off after 20 minutes
there are bad solder connections on the pictury tube drive module. have it fixed at a repair shop.. the tech will be mystified that you know what the problem was..lol..
Nov 12, 2009 | Televison & Video
Samsung DLP 50
check the input board for AVI make sure it is not dusty and that all the connections on the board are good you may have a bad solder point or that board is bad ,also possible video ctrl board
May 31, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Picture dimming and an ominous clicking sound
If this set is really only 5 weeks old, place a warranty service request for repair. This should not be happening. Either the ballast is bad or the lamp. In any case, either should be covered under warranty.
Please keep us updated.
Thanks,
Dan
Feb 13, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Toshiba 61H70 Weird Convergence Issue?
They may have gotten some cheap convergence ICs, thats a real possibility. I would recommend switching the two origional STK392-110 with some STK392-150 they will run alot cooler and last alot longer. Just use a good coating of heat sink compound on the back of the ICs. I will post a link where you can get top quality Convergence ICs and they provide free instalation instructions with pictures so you can do the job yourself in under an hour and save quite a bit of money. Heres the link.
http://servicemanuals.vstore.ca/
May 22, 2008 | Toshiba 61H70 61" Rear Projection...
Distorted picture
Being as the problem comes and goes this would suggest that the convergence Ic's are simply un-soldering them self from the board, If you catch this soon enough a simple re-solder will fix this
Feb 26, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Distorted Picture Proportions
well i beleive ur tv still have a warranty since it is purchased less than a month ago according to you. i suggest that u use it and have it check with their technician. it seems that there is an internal problem with your tv, particularly the vertical circuits. did u try to hook up another tv? this symptom is caused by a poor vertical linearity wherein the image is compressed or stretched at the top or bottom of the raster
Jan 16, 2007 | JVC AV-32F476 32 in. Television
Vizio L32 32 in. LCD HDTV Logo
339 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
