Question about Disney DTD1363-CAR 13" TV/DVD
Some of the input sockets have pushed inside the housing
How do I open the housing to the TV.
  • mike_banyard Feb 14, 2009
    I await the diagram, thank you.
  • 679 Answers
Here is your complet answer, follow the below link>>
http://www.fixya.com/support/t1666458-some_input_sockets_pushed_inside_housing
Posted on Feb 14, 2009
  • Disney Master
  • 19,396 Answers
I will see if I find a diagram , that is qute difficult.
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
How do i replace a brake light
Open trunk. look for plastic access panels near where your brake lights are(inside trunk). Remove the panels. Turn bulb housing counterclockwise until you can remove the housing from the lens unit. Push in bulb and turn a little bit counterclockwise until it will come out of the socket. Read the number on the bulb. Replace with same number bulb. Installation is the reverse of removal.
Oct 09, 2010 | 1999 Ford Taurus
I need to replace my tail light and I can't get the cover off. How do you do it? or does it come off from the outside? I see no screws.
Generally you access the tail light bulb from inside the trunk. Open up trunk, pull back carpet and you should be able to see bulb housing, twist housing and pull out of lens socket. If you have a new bulb, you will be able to tell if it is a push in bulb or push and turn to release.
Sep 02, 2010 | Oldsmobile Aurora Cars & Trucks
Can not understand how to change tail light bulb on nissan Versa.
The whole tail light assembly must be removed.Pop out 2 plastic covers near the tail light in the trunk. inside there are 2 bolts,one at the top and one near the bottom..Use a 10mm long socket,1/4 inch, with about an 6 inch extention on it.One of the bolts ( top, is off center) I put some heavy grease in the socket to hold the nuts from falling off when they come are off,so they don't fall behind the plastic wall..After you get them off,this is the "trick to remove the whole assembly without breaking it.It is very tight and hard to remove it due to a cliip at the front ,forward part of the light assembly.on the outside front,on the fender,Squirt some WD-40 on the pointed top part of the plastic light housing,letting it run down behind the housing on the outside. It has a clip in behind it on the fender.If you don't lube it ,it is very hard to release..Now I used the open end of a 1/4 inch socket extention to push on the lower bolt,inside the trunk,and you will see that the light housing will start to come out.do not force it.Get a piece of thin,strong string and make a loop out of it.Tuck the string behind the pointed tip of the housing,on the front part of the fender,so it will help pull the housing STRAIGHT BACK,while pushing on the bottom bolt inside of the trunk.This gives you 2 pressure points to pull and push out the housing.if you don't do them evenly,at the same time,you may end up breaking off the corner outside piece on the fender.If you bend it,it may break the plastic.
I know this sounds complicated when you first read this,but it WILL work,without damaging the tail light housing !!!
The dealer would probably charge you at least $ 50 to $75 to do this job.I am from Canada and I hate the Nissan dealerships.They don't want you to do ANY maintenance by yourself...
GOOD LUCK !!!
Aug 15, 2010 | 2007 Nissan Versa 1.8 Sl Hatchback
HOW TO CHANGE HEADLIGHT
  1. Open the hood.
  2. Remove push-pin fasteners from the grill assembly.
  3. Tilt the grill assembly forward and lift it up to remove it from the vehicle.
  4. Remove the fasteners from the headlamp assembly.
  5. Push the headlamp housing lever up to disengage the headlamp housing from the headlamp housing pocket.
  6. Turn the bulb socket being replaced counterclockwise one-quarter of a turn while pressing the socket in firmly.
  7. Pull the socket rearward until the bulb clears the headlamp housing, and lift it up to access the bulb.
  8. Disconnect the wire connector from the bulb by lifting the lock tab and pulling it away from the plastic base.
  9. Remove the bulb assembly and replace it with the appropriate bulb.
  10. Reverse the steps to reinstall the headlamp assembly.
May 05, 2010 | 2003 Saturn L-Series
Lost the direct TV signal to the TV when nephew pushed a button on the remote (he doesn't remember which button) The other TVs in the house receive signals per usual.
Your nephew must have pushed the "Input" button on the remote. The TV is now looking for signal at a different input.
On the remote, press the input button until the TV switches back to the correct input. Make sure the satellite receiver is turned on so when the TV lands on the correct input, you will know it.
Dec 17, 2009 | Cars & Trucks
Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Nov 30, 2009 | Sony RDR-GX300 DVD Recorder
I cant plug my jvc to my tv .Each time i try,nothing shows up.
I am assuming that you have an AV cable which you need to have connected to your camcorder at the AV output socket, and the other end should have RCA phono plugs (one red, one white and one yellow) which usually connect to three corresponding sockets on the front or side of most modern TV sets, these may be inside a front panel which opens. Once connected, you need to select the appropriate AV input on your TV remote, very often this will be "Front AV" or AV3 or AV4, you need to check your TV instruction manual to be sure of which input is required for your specific model of TV...hope that helps!
Oct 13, 2009 | JVC GZ-MG130U Camcorder
Sound but no picture on either SCART socket inputs
open the tv and check for dry joints on the jacks of AVS, if no dry joint is found
the ariel in put is different from AV inputs
change the AV in IC. AT THE W/SHOP
Apr 25, 2009 | Goodmans 257NS 20" TV
HDMI from laptop to DVI plug on Hitachi big screen TV
Have you cycled thru the inputs on the TV? Should display under the DVI input setting. Use input/source button on your remote to cycle thru inputs.
Hope this helps
Jul 06, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Disney DTD1363-CAR 13" TV/DVD Logo
48 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
