Question about Philips Magnavox 27MS343S 27" TV
Need manual can not get picture with cable hooked up but vcr works fine.
  • 2,035 Answers
Picture gets fuzzy especially the writting on 2000 Sansui tv
This could be multiple things. If the fuzzy picture is on your regular cable channels and the tv is hooked up directly to the cable then it is a signal issue. Your cable signal is probably too low because it is either split too many times, a splitter went bad, a piece of cable went bad, you have RG-59 cable rather than the much better RG-6 cable. Another solution is if there is a vcr hooked up, the cable jack on the vcr could have gone bad, the vcr power could be on which will cause a fuzzy screen. If you have a vcr try to bypass it and hook directly to tv. If that fixes you problem then it may be the vcr or the wire from the vcr to the tv. If you have no vcr then I recommend buying a cable amplifier and hooking it up. This is a band-aid solution but it could work long term if it's just a matter of weak signal. If that does not fix your problem I would recommend calling a cable professional to evaluate your problem. Could be the line from the pole to your house or any of the wiring in your home.
Jul 10, 2010 | Panasonic CT-32SL15 32" TV
Connecting DVD/VCR to TV
I called Sony and they guided me through it and all works fine now TY
Mar 19, 2009 | Sony FD Trinitron WEGA KV-32FS200 32" TV
TV & DVD HookUp (No Box) Can't get picture
As far as I know, my Go Video machine when there was no box involved...
The cable came from the wall to the IN of the Go Video box. Then another cable coming from the OUT of the video box and to the IN to the TV. TV should be on channel 3. As far as I can remember, I don't need to push the TV/VCR button, but instead, have to channel down to below channel 2 on the TV to the LINE/INPUT selection. Once you go there, and the Go-Video machine is on, you should be able to see a clear picture.
You'll push the TV/VCR button if you want to toggle back and forth from the VCR picture to the TV picture (which will be technically blank since it's on the 'line input selection.)
Hope that helps.
Mar 08, 2009 | GoVideo VR3845 DVD Recorder/VCR
Element FLX 3210 not scanning for cable channels
Jan 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Dec 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The vcr and the dvd are separate entities in the same box. I have the DVR610 Toshiba and I connected it to my TV with an HDMi cable and it worked fine for the DVD but I couldn't get the VHS to play. I hooked up RCA cables as it describes in the manual and it works fine. In other words you need a separate connection for each entity.
Sep 29, 2008 | Toshiba DVR610 DVD Recorder/VCR
Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Jun 17, 2008 | Gateway AR-230 DVD Recorder
S-video imput not working
I had the same problem. Solved it by going to Set Up, Video Selection, then choosing the S- Video input jack, vs the default. Now if I could just get it to pass video when the unit is off...
Dec 27, 2007 | Toshiba D-KR10 Multi-Drive DVD Recorder
No picture
Tvs usualy have a few ways to hook them up. One is a coax cable this is the silver one in the back that you screw in a cable. The second are RCA cables these are the ones that are yellow, red and white. Yellow is always the video and white and red are for audio. If your using the coax cable your tv needs to be on channel 3 or 4 you may have to force the tv to go to that channel by pushing 03 on the remote. If you are using the Rca cables then you need to change the tv to "video 1" or "video 2" this changes the tv from tunner mode to aux input mode. Most DVD players dont have a coax out so you have to use the rca plugs. Some tvs have the rca plugs on the front (video 2) and the back (video 1) or line in. Some tvs have line out also so you need to figure out wich way you have it hooked up. Do a search for the model of your tv and it should show a diagram on how to hook it up.
Apr 07, 2006 | Emerson EWD2003 DVD Player/VCR
Philips Magnavox 27MS343S 27" TV Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
