Question about TitanNet Bike USA Titan Pathfinder Ladies 18 Speed Mountain Bike
Mens Titan Pathfinder Mountain Bike
The rear wheel part that hold the gears is stripped and is missing a part. Where can I find affordable parts and exactly what is that piece called?
  • 5 Answers
If the gears will no longer go back on the bike, I would recommend buying a new wheel (including a new rear hub). It is usually easier and more cost effective to buy a wheel than to replace the hub. To replace the hub (the part that is stripped on your bike) you would also have to remove and replace spokes, etc. Search online for the wheel size you need (probably 26" - you can check the tire size) or take to a reliable bicycle shop and they will gladly help you. Anyway, you need a new hub but probably better off getting a new wheel - much easier.
Posted on Aug 27, 2009
What is a decent replacement rear derailleur for a Mongoose 26" Ledge 2.1 Mountain Bike?
Get the kind that has a lever shift instead of the grip shifter. The plastic part that holds the spring breaks easily. The lever shifter has been going strong on my bike for 6 years without a problem
Aug 31, 2016 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
Have an older Huffy female 12-spd road bike that is missing the rear wheel assembly. Looking to find a replacement as well as instruction manual...wheel assy. more important. Thanks.
Unless you have a deep sentimental connection with the bike, it may not be with it:
Rear wheel - $35-$45
Rim strip/tape - $1
Tube - $8-14
Tire - $10-20
Gear cluster - $25-40
New Huffy is about $150-250
You might be able to find a used bike or wheel at a garage sale that would work.
Sep 19, 2015 | Huffy Cycling
Shifting gear shifter... the handle has broken and I want to replace... what should I use. Thanks
A replacement can be purchased on ebay or amazon or your nearest bike shop. They can also help you install the new part
Jul 30, 2014 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
My son's Mongoose XR75 Mountain bike's gear box is
Derailleur. Everything on a bike that bolts on can be replaced. Take it to a bicycle shop for assessment. Special tools are involved.
Jul 08, 2011 | Cycling
I bought a mountain bike with Shimano Altus gears over the net with most of the assembly in place. Have indexed the rear gears which work fine. Did the same for the front deraileur works changing up but...
There are a couple of possible problems. You can try backing off the cable tension a little bit at the shifter and running back and forth through the gears adjusting as you go till it hits 2nd coming down.You can also try backing off the High limit screw on the derailleur. This will allow the shift to start a little farther from the bike hopefully hit 2nd. Hope this helps.
Sep 12, 2010 | Mountain Shimano Altus Front Bike...
How hard is it to put together a 21 speed bike?
Very hard it's not something for the faint of heart, make sure you wear latex gloves because certain metals are very caustic to feminine skin. Put your pants back on and build the darn bike PAL. Good Luck! I hope that I was inspirational, on your bike build.
Aug 13, 2010 | TitanNet Titan Trailblazer 21 Speed Mens...
Mongoose tactic mountain bike / loose crank on chain side. How to tighten.Chain ring moves with it. Makes clicking noise.
The crank has to be removed to tighten the nut that holds the gear on. I assume that is your problem is with the chain gear on the sproket that is loose
Apr 21, 2010 | Pacific International Mongoose 26 in. Mens...
My son just bought a 26" Huffy Jolt mountain bike. The rear sprockets spin freely when the pedals are cranked either forward or backward - - that is, there is no coupling to the rear wheel. What can I...
The plastic is to stop the chain from touching the spokes, it cannot cause this problem, either the chain is not on a sprocket correctly or the rear cluster(sprockets) is not working.
Some spray lube may help, but if it is new, take it back to the shop.
Apr 18, 2010 | Huffy Mens Mountain Bike - Crimson Red
Brand New mens Diamondback mountain bike, with
You may have a locked up wheel bearing or you may have an object stuck in the chain. Can you spin rear wheel by hand? If not, most like bearings, if so, then you may have bent gear tooth or something stuck in chain. Check derailer to make sure it is not bent
Aug 17, 2009 | Cycling
TitanNet Bike USA Titan Pathfinder Ladies 18 Speed Mountain Bike Logo
225 people viewed this question
Top TitanNet Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a TitanNet Cycling Expert? Answer questions, earn points and help others
