Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
TV shutting off.
Press power button "ON" then hear static noise then shuts itself off.
  • jackbailey Feb 16, 2009
    where is the fuse cut off at
    Genius:
  • 1,239 Answers
Hi
its definitely an fuse cutoff problem ...fix it and ur problem will be solved
Posted on Feb 14, 2009
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
It keeps shutting itself off ?
When does it shut itself off? Is this happening time you press the power button and during the boot cycle it shuts off without completing the boot to windows? If it shuts down after you've worked on it for a while it could be that it is running hot. If you let it sit a while to cool off then press the power button, if it completes the boot cycle and allows you to work it is definitely running hot. Normally when they run hot if you immediately try to reboot, it will fail. If you let it cool off it will boot successfully. Computers run hot because of a fan not working, dust clogging the fan vents or the Thermal Paste around the CPU and Heat Sink has become hard or too thin to keep the unit cool. If it's not running hot you might have a power supply or motherboard issue. Try removing the power cord and press and hold the Power Button for 30 seconds to release any Static Buildup. Then plug the power cord back in and try to reboot.
Mar 18, 2012 | Dell OptiPlex GX280 PC Desktop
Lighting McQueen 13" tv/dvd combo.
It is an indication that you have a problem on the power supply on the main board.
Nowadays tv will automatically shuts off if there was a problem on the power supply.
It is quite technical so if you are not an expert I've advice you to send it to a repair shop or look for a qualified technician to isolate the faulty parts on the low voltage power supply and do re-soldering on some dry joints on the main boart because sometimes dry joints affect the performance of the regulated power supply...
Thanks for using fixya...
Jan 08, 2011 | Disney CARS 14 TV/DVD Combo
TV KEEPS SHUTTING ITSELF OFF
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is BP9600224B you can find it here: http://www.discount-merchant.com/Samsung-BP96-00224B-OEM-Replacement-LAMP-BULB-BP-p/samsung-bp96-00224b-oem.htm?Click=48173 .Have a blessed one!
Apr 29, 2010 | Samsung HLN5065W 50" Rear Projection...
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
HL-r6167w wont start up (HELP)
it sound like the color wheel is bad
Nov 26, 2007 | Samsung HL-R6167W 61" HDTV
Won't turn on...
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
Dec 19, 2006 | Samsung HCN4226W 42" Rear Projection...
TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
