Question about Endless Summer 233010 Natural Gas Stainless Steel Commercial Patio Heater
Endless summer 233010 natural gas patio heater shuts off after 10
Minutes. hard to restart. also need a place to buy the parts. thanks
  • Mark Egan May 11, 2010
    Chances are you have one of several problems -
    1) Bugs or spiders have built nests inside of the main burner tube, just above the gas valve.
    2) If the unit is over 3-4 years old, the regulators tend to quit operating properly. If you have followed the proper procedure for resetting the propane bottle (close propane bottle valve all the way, close the appliance valve all the way, make sure the connector between the propane bottle and appliance are tight, open propane valve 1/2 turn, light appliance pilot and allow to burn for 30 seconds, open appliance valve all the way, open propane valve all the way.).
    You can buy a replacement regulator at the home repair centers (they typically have replacements for grills.). You may need to get a fitting to allow the new regulator to fit to the heater.
    Reply back if this fixes the problem, or you have additional questions.
  • 333 Answers
SOURCE: need part # 56-01-127 pilot assembly
Call this # and order 1-800-762-1142. I hope this helps.
Posted on Dec 19, 2008
johnsonr1
  • 91 Answers
SOURCE: Replacement regulator required for Endless Summer patio heater
These regulators can usually be purchased from Canadian Tire or Home Depot. If you are unable to locate the exact replacement, email the model number located on the regulator and I will locate one for you. I am in the GTA and can be contacted via company website. www.emshvac.com
But one question, why do you think the regulator is defective? These rarely fail.
Posted on Nov 04, 2009
cadesertmax
  • 274 Answers
SOURCE: Left Patio Heater out for winter, now won't ignite
It could be just a blockage in the pilot assembly, you have to take the head apart to find and clear the blockage. While you are in there you check for a blockage in the main burner orifice as well. If it is just a blockage, then you don't have to replace anything.
If this doesn't get the gas flowing, try replacing the regulator.
Posted on Jan 11, 2010
cadesertmax
  • 274 Answers
SOURCE: Have Endless Summer patio heater. I got the burner
It could be the thermocouple, but you have to take the head apart to replace it. If you got the main burner to fire, then the thermocouple is probably ok. Try changing the regulator, easy to do and not to expensive. If that doesn't work, try taking the head apart and cleaning the pilot and main burner orifices, do both while you are in there. If you are not comfortable doing this, hire someone.
  • 3 Answers
SOURCE: outdoor patio heater won't stay lit
I have a Charmglow Patio Heater Model SRPH02, it needed a Thermocouple and searching the net was hard to find an ariginal part, but here it is, call 1-866-814-0585 $3.95 +6.00 shipping the original part.
Posted on Jun 17, 2011
My gas endless summer heater shuts the flame off abruptly after 5 minutes or so. why??
The first consumable part to fail on a gas patio heater is the thermcouple, these can last anywhere between 1 year to 6 years. When faulty it will cause the heater to shut off when turned on at pilot. Found this site very useful patio heater problem solving.
Nov 18, 2011 | Endless Summer 233010 Natural Gas...
Flame stops suddenly after running for a while. Yes, there is fuel.
Check that there are no leaks, to do a leakage test see patio guide to problem solving. If OK then check the thermocouple, when worn out they will cause the pilot to switch off.
233010, Pilot fires up and heater lights ok but shuts itself off after 5 min. Is one of the thermocouples malfunctioning?
It's possible, Cal, but it could be that the burner and the pilot assembly simply need a thorough cleaning. As, insects love to build nest in the heating part, when they are not being used.
If after cleaning the unit thoroughly, you still have the problem, you can purchase the Thermocouple from the manufacturer, Blue Rhino 1.800.762.1142.
I hope I was able to help you and thanks for choosing FixYa.
Sep 12, 2011 | Endless Summer 233010 Natural Gas...
My Blue Rhino Endless Summer infrared patio heater will light, but after a few minutes, it will go out. I suspect the thermocouple. I took the entire heater apart, removed some dead wasps, dirt, etc. ...
You can purchase all need parts from Uniflame (a division of Blue Rhino) by calling Customer Support
800.762.1142. Have you model number handy when you call.
Hope this helped you.
May 28, 2011 | Endless Summer 2009 Open Flame Patio...
Flame goes out after 5 to 10 min then have to wait until it cools to relight
Unless, it's the wind blowing the flame out, I'd say the Thermocouple needs to be replaced. This is based on what you said, " have to wait until it cools to relight." The reason for that, is that the burner control valve has to reset itself. You can also check the pilot and pilot orifice for obstructions. Blowing it out with a can of compressed air with a straw nozzle (like you clean your computer with) may also help solve the problem. As insects like to build nests in these heaters, when they are not in use.
Endless Summer Patio Heaters are manufactured by Blue Rhino under the name Uniflame and Endless Summer. You can purchase any necessary parts from them online, if necessary.
Hope this helps you to solve your problem.
Mar 23, 2011 | Endless Summer 233010 Natural Gas...
I need to convert a Endless Summer Blue Rhino patio heater Mod. No. 233010 from naturalm gas to propane , what do i need
You would need new pilot and main burner orifices. You would also have to ask the dealer/manufacturer if the valve on the propane heater will work with propane. It may not because the propane tank will have to be connected to the heater using an LP hose and regulator. You would then need to take apart the heater to install the new orifices. Considering the cost of a new heater that is set up for LP, I do not believe the conversion to be practical.
Feb 24, 2011 | Blue Rhino Uniflame - 233010 - Endless...
Heat does not turn to high. I can turn the KNOB to high, but the heat does not increase. The heater used to turn red when it was on high, but does not now do that. How can I incread the heat output. Model:...
It sounds like you are not getting enough gas at the main burner. Possible causes, bad regulator, easy to replace and relatively inexpensive. You could also have a partial blockage in the main jet orifice, not letting enough gas through. You have to take the head apart to service the main jet orifice, do the pilot jet orifice while you are in there. If you are not comfortable doing that, hire someone.
Oct 12, 2009 | Endless Summer 233010 Natural Gas...
Need part # 56-01-127 pilot assembly
Dec 19, 2008 | Endless Summer 2009 Open Flame Patio...
Endless Summer 233010 Natural Gas Stainless Steel Commercial Patio Heater Logo
146 people viewed this question
Top Endless Summer Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
