Question about MyMusix PD-6070 MP3 Player
When turned on APPEARS then shuts off
And won't allow anthing further
Are you sure it isn't locked? If its locked, the "MyMusix" logo thingy should appear first, then it will have something like this...
<locked>
And then a few seconds after, it shuts off. The lock switch is on the back side of the MP3.
If that isn't the case, then perhaps it isn't charged enough.
But that's all i know of.
Posted on Feb 19, 2009
Lost pairing of iPhone 5 to Panasonic kW tg7841. iPhone will not pair.
I recommend turning the Panasonic back to pairing mode. It probably came with instructions on how to do it.
Jan 28, 2015 | Apple iPhone 5
1992 jeep wrangler yj 4.0L, I6, fuel shut off
I am not sure of your question, there is not enough information. However, I had a problem with a diesel Grand Cherokee that appeared to have a fuel shut off problem, it turned out that the header pump was worn out, and it further turned out that the Cherokee had a history of the header pump wearing out.
The header is the pump that supplies the injector pump with diesel fuel from the tank, and if this pump goes, not enough fuel is supplied to the injector pump causing the engine to cut out, and having to be bled again. As soon as the engine cools down, the pump appears to be working fine again.
Another possibility is that you might have a problem of sorts with your engine. The engine control computer senses the problem and turns the engine to limp mode, which allows the engine to work at a much reduced power output, giving the impression of diminished fuel supply. This allows the driver to get the car to a service agent before further damage is done.
Give us some more info to give you a better answer.
Sep 12, 2013 | 1999 Jeep Grand Cherokee
When turning on. The windows appears. But all the icons are high lighted and won't highlight.
click in a open space on the desktop. Or shut down, unplug, remove battery, plug in, reboot.
Dec 23, 2012 | Computers & Internet
F2 and a spanner appears after it is turned on to operate
Hi
F2 error is displayed when control won't sense motor to be rotating, usually occurs due to frozen/bad motor or stuck motor rotor or the RPS sensor or a bad stator assembly. If the motor rotor spins freely and both impellers are securely attached then the issue is with the RPS sensor. If the motor won't rotate then it is the motor rotor that has to be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
When I turn on the vehicle the headlights and windshield wipers come on and won't turn off. When I turn the key off there is a delay before it actually turns off and the headlights won't turn off.
This sounds like an issue with your ignition switch. Basically what is happening here is that you are shutting off your vehicle, but the ignition switch is not working correctly and is allowing certain accessories to stay on.
Jun 17, 2011 | 1992 Dodge Caravan
MyMusix PD-6070 MP3 Player Logo
Top MyMusix Audio Players & Recorders Experts
Greg Cann
Greg Cann
michael galang
Sandeep Shenoy
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
