Question about Electrolux Kenmore 5.8 cu. ft. Super Capacity Electric Dryer
Tumble dryer keeps stopping
My kenmore tumble dryer keeps stopping, makes and intermittent beeping sound and displays the letters E9E in the display. I can't find any refernce to this dispaly in the instructions. Can you help please.
Frigidaire dryer error code e9e
Hello zabbster - Typically E9E means that there is an issue with the control board receiving low or intermittent voltage and you would need to contact a professional to verify the house wiring and confirm the power supply.
Sep 25, 2012 | Frigidaire Dryers
My 1988 washer/dryer combo Model LSG1000 is showing an E9 code for the dryer. Do you know what that means?
The "E9E" code means Low Voltage is seen at the Control Board. Make sure the RED wire on the Control Board that connects to the Heater Relay is not loose or burnt. This is the LINE ONE voltage supply to the Control Board and if it has a bad, loose or burnt connection it will cause E9E to display. If there are no loose of burnt wire connections then the control board will likely need to be removed and replaced.
Aug 16, 2011 | Maytag Dryers
I HAVE A FRIGIDAIRE DRYER MODEL LEQ2152EE0 IT WAS WORKING ONE NIGHT AND WENT TO USE IT THE NEXT DAY WHEN I PUSH START IT MAKES A FEW SOUND FROM THE CONTROL BOARD AND THEN FLASHES E9E ON THE DISPLAY ANY...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2011 | Dryers
DR code on display
When I push the start button on my Fridgedare dryer model
gleq2152es it makes a click and E9E appears on the display
sceen.
Mar 15, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Model glgq2152es error code E9E
The E9E code is a low voltage/intermittent voltage alert. It says in the troubleshooting manual to press cancel when this appears.
You may want to check the plug or the wall socket to make sure there is not a short occuring. The fault code is not saying your dryer is broken, just to check for proper voltage.
Jan 10, 2010 | Washing Machines
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore 94082 gas dryer: Runs a short time, then stops, E9E error
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 25, 2009 | Kenmore 67082 Electric Dryer
Kenmore oasis electric dryer beeps and displays code F45
We had this error on our machine for about a year before we finally got sick and tired of it. Our dryer was purchased in 2006.
Here is the solution: the code means there is an error on the thermistor. Our thermistor was loose, as were other electrical wires. My husband tightened up all the connections and the thermistor, and we have never had this error again.
However, we will never buy these machines again either, because we have had numerous other errors on the washer and dryer.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Auto stop problem.
ck to see if wrinkle guard or some such feature is activated ..most dryers have a cool down followed by intermittant tumble without heat to reduce wrinkles
Nov 17, 2008 | Frigidaire GLGQ2152ES Gas Dryer
Electrolux Kenmore 5.8 cu. ft. Super Capacity Electric Dryer Logo
73 people viewed this question
Top Electrolux Dryers Experts
Electrolux
Electrolux
paul
paul
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
