Question about Sony PlayStation Portable (PSP) Console
T my WEP key is there a way I can find it
Trying to add new laptop to my wireless connection asking for WEP key and I don't remember what that password is. How can I find this out
    Brigadier General:
  • 8,619 Answers
Hi!
WEP consists of 10 number and letters and is usually under your Wi-Fi (wireless) router...enter that code into ur PSP and it will grant u access to the internet.
Or type 192.168.1.1 or 192.168.0.1(which ever your router has set to access it) into your web browser and your loginour password is usually admin and Password is usually blank (as in don't type anything in it) for your router will pop up from there you can find your wep key or you can turn the wep off so your psp will not need a wep key.
Please rate this solution.
Thanks
Rylee
Posted on Feb 14, 2009
I'm trying to connect wirelessly, but its asking for a sercurity key code! What is this and where do I find it? Help, pls!
Network security key
Some later model wireless routers have the Password (ie.Encryption key) and the SSID already configured in the wireless router and this information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adapters in your computer/laptop.
If these settings do not suit you, then it can be changed to suit your requirements.
The encryption key secures your data and wireless connection from unauthorized access.To configure the wireless settings in the router, connect a LAN cable from your computer to the wireless router, then open a Browser on your computer and enter the router's configuration IP address, then enter the admin login and password and then go to the wireless settings and configure the SSID and Encryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2 key.If you use the Passphrase method select either WEP or WPA or WPA2 to generate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to 63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born in January 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router. http://www.fixya.com/support/r10267861-network_security_key
Nov 22, 2012 | Computers & Internet
Don't know my password
Are you looking for wireless network password or Linksys router password?
If you are trying to connect to the wireless network then it might be asking you for the wireless network key or the passphrase.
You can open the setup page of the router and check the wireless settings.
Read Wireless network key WEP WPA
Dec 12, 2011 | Linksys Wireless-G WRT54G Router
How to i password lock my router for my wi-fi
There is an option called WEP (Wired Encryption Privacy)
You have to loginto the wireless router and enable the WEP authentication.
It will ask you to type in a key and again reenter the same key.
Please do remember the WEP key as next time you try to connect to wireless your laptop will ask for the WEP key. enter in the same key and you will be able to go to internet.
Those who wants to use your wireless need to enter the same key. If you dont want someone to access your wireless then you dont provide him the key.
Dec 02, 2010 | Computers & Internet
Trying to get on internet but its asking for a wep key or a wpa key I just completed hook up to netgear router have desk top and a wirerles lap top laptop is asking for info
The WEP and WPA key is configured in the router's wireless settings.
WPA is a stronger encryption than the older WEP encryption, I suggest you use WPA or better still WPA2.
To secure your wireless network, configure the wireless router and the wireless card in the computer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 25, 2010 | Computers & Internet
Trying to connect asus netbook to wireless connection
If you open your Network window from the start menu, at the top you will see "Add a wireless device". Follow the instructions and this should get your wireless connection with WEP key add. (When you select your router, you will need the WEP key at hand. You can get this by going to the web page of your routers IP address.) Good Luck.
Feb 09, 2009 | ASUS Eee 4G Notebook
Problem connecting wirelessly using netgear router MR814v2
Hi, you should consider changing your security to WPA-PSK or WPA2-PSK encryption instead of WEP as WEP can be cracked in a matter of minutes, even 128bit keys can be cracked easily. Plus there's no confusion over the four WEP keys generated.
With WPA you choose the key so it can be a word instead of random key, making it easier to remember. Just make sure its not a simple word that can be guessed, and use random numbers or characters so something like 64ranDomWordz92. Its case sensitive too so chucking in capitals makes it even harder to guess. Don't forget to write it down in case you forget it, make sure you write it correctly.
Now you know which key your using, go to manage wireless networks on your laptop and delete any profile you have for your network. Now when you try to connect, it will ask for your WPA / WPA2 passkey, just type it in and hit enter, you should now be connected.
Let me know if you need help with any of the above.
Jan 21, 2009 | NetGear DG834G Router
Wireless router connection problems
Assuming "cannot connect to linksys router directly" means you cannot connect to a Wireless Lan managed by Linksys router,
1) try to connect new computer to LinkSys Router using a Lan cable, add new PC to your network.
2) recover protocol (WEP or WPA) and Key of WLAN (Passphrase or Key: TKIP or AES) either from other PC on same network either from your Router.
3) If you missed actual key you must connect to router and reset it to a new key to be eventually used for every connected device.
Call for detail on this possibility
Dec 29, 2008 | Linksys Access Point WAP54GP Wireless-G...
Need wep to connect laptop from school to home network while at home
YOU SHOULD BE ABLE TO FIND THE WEP KEY IN YOUR INTERNET CONNECTIONS. IF THERE IS NO WEP KEY, JUST CREATE ONE AND YOU SHOULD BE GOOD TO GO. THIS CONNECTION LINK HAS A TAB TO SHOW CHARACTERS IF THE KEY HAS BEEN ENTERED. YOU WILL PROBABLY HAVE TO REMEMBER IT, OR JUST CREATE A NEW CONNECTION WITH A NEW WEP KEY! THAT IS THE EASY WAY! GOOD LUCK.
Oct 30, 2008 | NetGear WG511 802.11g/b Wireless Adapter
Wireless connection
Try setting up initially WITHOUT any WAP key, IE: UN-secured etc... when ya connected THEN add a key etc..
au.playstation.com/support/ps2/wizards/ps2_wizard_ng_routerconn.jhtml
Try this troubleshooting link above.. Remember Google is your friend ... :)
Jul 28, 2008 | Toshiba Satellite A205-S4617 Notebook
WEP key for 2wire 2700
The WEP number is in a wireless router near you, you must have a wireless router been setup in your home, then you have to program it. you choose your wep key code and only will have access to this wireless network.
contact your local IT or computer repair guy to help you with this process.
Jun 13, 2008 | 2wire 2700HG-B Router (2700HGB)
Sony PlayStation Portable (PSP) Console Logo
82 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
