Question about Logitech X-230 Computer Speakers
Bass Flow Tube
The Bass Flow Tube has come un stuck and is rattling around inside the subwoofer so i need to take the unit apart and repair it, however, when i remove all the screws from the back plate it still doesnt come off and i have no way of getting inside it, Anyone know how to get inside the sub??? Thanks
Carefully pry off the gray metal mesh covering the speaker. Don't pry on the plastic ring - you have to remove the metal mesh from the plastic. Remove the six screws holding the speaker in place, and remove the speaker. Finally, re-glue the tube into the port. Wait for the glue to cure before turning the speakers on again.
Posted on May 19, 2009
I have the same problem with this product maby its a technical problem
Posted on Nov 11, 2009
What could be rattling inside the hand held shower head
It sounds like the flow restrictor may have come loose and be rattling around in their. There is no way to open that shower head that I am aware of. If it really bothers you, buy new one.
Oct 28, 2015 | Moen Home
Bass speaker is making a rattling or cracking now,,,and it doesn't have a lot of bass in my system
You have a blown subwoofer. The only option is to replace the speaker, unfortunately they cannot be repaired.
Sep 20, 2013 | 2006 BMW 750Li
I turn on my subwoofer and the volume is turned down and it makes a loud buzzing sound, and its not even hooked up to the amp, just pluged in. Thank you, Joel Arntsen
You might have blown the speaker. This happens when you play things too loudly and you ruin the speaker inside. You can test this by playing something with a decent amount of bass and turned up a bit. If you hear like a "rattle" in the sound or like something isn't right in the heavy bass notes, then you definitely blew the speaker out. This isn't a tragedy. They're fixable if you bring them to a place that repairs speakers. But I would definitely test it first by hooking it up and playing a loud song with a lot of bass. Hope that helps a little! Please rate my solution!
- Frankie
May 06, 2011 | KLH ASW10-100 Subwoofer
Sub-woofer driver rattle/buzz.
Bad news! It sounds like the coil is rubbing inside the magnet of the speaker! There's no cure, when the cone is warped it it knackers it up. Had the same problem some years ago with a Wharfedale speaker. Someone told me you can hit it on the part where the cone joins the magnet -with a hammer!
Anyway it didn't make a bit of difference! And the speaker was chucked.
Feb 09, 2010 | Polk Audio PSW150 Speaker
Kinyo t3100 bass speaker has a rattle when playing music
try turning the bass down and make sure that the rattle is inside the speaker check around it and see if its not something nearby the speaker it could be something came off inside.
Oct 08, 2009 | Kinyo NB-100 Computer Speakers
Bass sounds muggy it rattles alot when volume is turned up. It just started to happen. What is happening? The bass from the head unit is at -8 while the subwoofer level is a +15.
Have you had it checked out, if it rattles when bass hits hard, it could be busted, have you had it up extremely loud before? If so, that is probably what done it, otherwise, I would call whoever you bought it from, and ask them if they know anyone who has had similar problems to yours.
Sep 03, 2009 | Eclipse SW8102.4 Car Subwoofer
Subwoofer rattle
Try filling the inside of the enclosure with insulation [roof insulation will work ] or a small pillow just to see if its the box or the driver rattling if its the driver you might have to secure it to the enclosure with screws or something ,
May 18, 2009 | Atlantic Technology System 170 System
Taking apart a JBL N24
I removed the tweeter and found that I could stick two fingers through the hole and touch the back of the speaker. I was afraid that if I applied to much force I would break something, but after seeing a schematic of the speaker I realized there was nothing else attached except the wires. So, I used some muscle. It took a lot of pressure, but the speaker finally popped out. I was able to tighten the one screw that held down the circuit board in the back and re-assembled the speaker. Problem fixed.
Nov 15, 2008 | Audio Players & Recorders
Problems with bass when turning up radio
You might have blown a speaker, or more than one. Check this first before you start trouble shooting the radio.
Keever
Mar 05, 2008 | Car Audio & Video
Logitech X-230 Computer Speakers Logo
717 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
