Question about Dell Dimension 8200 PC Desktop
Can Dell Dimension 8400 intel celeron work with 3 gig ram
Ram
  • 24 Answers
Yes it can but try to match up at least two, to gain the advantage of dual channel and when you buy your extra ram, check that it matches the other two that you have in size, speed and technology (like 3x1G DDR2 same speed). Also you may have to play with which slot to put the third one but I had this one run with three modules before yes.
Otherwise your Dell Dimension 8400 can see upto a maximum of 4.0 GB memory, with maximum of 1GB per slot in 4 (2 banks of 2) memory slots.
Posted on Feb 14, 2009
I have recently added more ram memmory to my Dell dimension 8400. A few days later my pc starts up till everything is on the screen then switches off completely. Is this a possible power supply problem??
If you added ram of a different make that can happen.What I mean is that if you put ram of a diferent make on twoslots then you can have that problem. Your ram should be all of the same manufacturer. However sometimes some different ones work. Try changing your ram's position and see what happens also take of the ram and see what happens. If your computer starts working then the ram is the problem. Try this and tell if it worked.
Nov 18, 2011 | Dell Dimension 8400 PC Desktop
My 6 year old Dell Dimension 8400 quit working completely.
Depending on the symptoms, you may have different faults.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Flashing Amber power LED, normally power supply
AAGG Diag LEDs normally bad RAM
Solid Amber Power LED, bad motherboard or Expansion card connected to it.
If you need a motherboard a Precision Workstation 370 motherboard is essentially the same and is available, (8400 motherboards are scarce)
http://shop.ebay.com/i.html?_kw=T7787&_kw=DELL&_kw=Motherboard
Feb 05, 2011 | Dell Dimension 8400 PC Desktop
Where should I look in the computer (Dell dimension 8400) for the problem windows shuts down and a blue screen error message saying page fault in a non page area.
Hi friend,
You need to check your ram in your computer.. i think your RAM is not good running...so try to change then ram ...then it will work..
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
I have a sahara laptop system model 661MX, with 512 MB Ram,Processor Intel(R) Celeron(R) 1.40 GHz, Now could i integrate 2GB of Ram In This ?
yea but when u gone to shop for this there after setup 2 gb of ram u checked ur lappy.but its working too better
May 07, 2009 | Dell Dimension 8300 PC Desktop
I need a new processor and motherboard for a dell dimension 3000
By the time you spend all that money you could have bought you a new Intel 2.8Ghz dual core processor with 4GB of RAM..keep the one you have for stuff you want to experiment with and buy yourself a new computer
Mar 10, 2009 | Dell Dimension 3000 PC Desktop
RAM
You may have bad or incompatible Ram . Verify that the memory you have is compatible. .
Machine name: Dell Dimension 3000
CPU options: Intel Pentium 4 or Intel Celeron
Chipset: Intel 865GV Chipset
HD Bus: Ultra ATA/100
Front Side Bus options: 800MHz FSB
Memory Speed options: PC3200 DDR400 184pin SDRAM DIMM
Special notes: The Dimension 3000 has two different bus speeds each of which takes different memory. You cannot mix the speeds.
Take the memory out and install one at a time. This way you can verify that the memory is indeed working. If you find a bad one, replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 8400
look at the manual but it's more than likelly the one furthest from the edge of the board. it may tell you in one of the applications, like check you device manager or down load a free copy of Soft Sandra, from their wesite, it will give you all of the spec's for enery component in the case. It sounds like a ram mismatch taker them out and look at the individual sticksyou may have 2x1gig modules and 2x 512 gig modules, that would add up to 4 and fill all of the slots.
Aug 09, 2008 | Dell Dimension 8400 PC Desktop
Ethernet Controller
Hi
E210882 is a number found on more than one Dell System Board. Dimension 8400 and 4600 come to mind. Possibly there are more. Secondly, E210882 is not a Dell Part number (DP/N or DS/N). While Dimension 8400 is a 775 socket, Dimension 4600 is a 478 socket. So they don't fall to the same family.
In any case the network controllers used on Dell System Boards are Intel and Broadcom.
To proceed, at least provide/confirm the system model. If this is not available, give the Dell Part Number.
Mile
Jul 10, 2008 | Dell (E210882) Motherboard
Dell Dimension 8200 PC Desktop Logo
111 people viewed this question
Alun Cox
