Question about Apple AirPort Express (M9470Z/A) 802.11g/b (M9470ZA) Wireless Access Point
Airport express streams audio for a short period then quits
I can start streaming a song to my stereo in itunes (ver 8) when, after about 0 seconds, it goes silent.  The progress bar in itunes keeps going as if the song is playing, but no sound.  If left alone for a period, it will stream again for a short time, then  quit again.  Throughout, the airport express is shwoing in the speaker selection box on itunes so I assume I'm not losing communications with it.  Help?
Note:  I have tried different stereos, and even tried an old airport express and have had the same problem.
  • RemiM Feb 14, 2009
    That exactly describes the problem I've been having for quite a while. Today it escalated and starting going off and on at intervals of a few seconds, but not consistent gaps in sound.
    Problem Solver:
  • 17 Answers
Make sure that your setup for the Express is set to "join the network" and not extend.
Also remember that with wireless technology there can be interference from microwaves, phones, etc.
If you are running programs that use a lot of bandwidth, this will cause the drop outs as well.
If you have a newer Express, another cure can be to use the 5GHz band for the broadcast channel.
Posted on Feb 15, 2009
Itunes and Spotify crash when connected to denon reciever
Yes it sound like you have a fault on the power amp section. Perhaps a faulty transistor? It might be difficult to sought out, unless you have a bit of experience in tracking down these types of faults.
Jun 10, 2017 | Audio Players & Recorders
I want to plug stereo cables with the red and white ends into my LG FB163 mini shelf stereo, so that I can use my Airport Express to stream music from iTunes, but I don't know where to plug the red and...
there should be an aux/analog in. if the analog/aux in does not use red and white rca jacks, then it must be a single 1/8th inch jack input, like a headphone jack, and you will have to get an rca to 1/8 inch "Y" adapter
Nov 06, 2010 | LG FB163 DVD/DivX USB Micro system Shelf...
I'm having trouble finding a reliable software to download that will enable me to play youtube/slacker/pandora (non- itunes music) on my Mac and listen through my stereo using my Airport Express,...
Welcome to Fixya community.
Please try download and Install MacTube Player to play Youtube video or music... Let me know the result please...
Also to play the music in stereo receiver please follow below steps.
  1. Plug in the Apple AirPort Express into a power outlet near the stereo. Connect an audio cable from the audio port on the AirPort Express to the audio in port on your stereo. If your stereo has a different sized audio port than the 3.5 mm one on the AirPort Express, you will need to use an adapter to connect it.
  2. Plug in an ethernet cable from the AirPort Express to your computer or wireless router for a wired connection. For a wireless connection, connect the AirPort Express to your existing home network, or use a computer with a wireless network adapter to connect directly to the AirPort Express.
  3. Connect to the AirPort Express with your computer as directed in the manual to run the setup with the AirPort utility. Follow the instructions on the screen.
  4. Open iTunes and play the music to your stereo. There should be a pop up in the lower right corner after you run the Airport utility.
Let me know how far you could able to reach in a result. Our expert friends are here anytime to solve your issue.
Thanks once again for joining us.
Have a good day.
Aug 02, 2010 | Computers & Internet
When playing sample songs in ITunes the songs pause and an "Opening URL" message appears with a message "rebuffering stream" in the box. I have looked for answers and some say the media player is the...
this is not a problem from the media player ..it is a connection issue ..when the flow of the packets into the connection streaming is not continuous ..its makes what is called under-buffering and will stop until the information are streamed again in the right way..This is happening only with songs you play from the internet or the itune storenot with ones already downloaded..
Jun 01, 2010 | Apple iTunes
Just installed Airport Express. I can select it from iTunes on my PC running vista. The music plays but songs intermittently stop...it like it can;s download fast enough...suspect the laptop can't send...
Make sure that between the laptop and airport express you don't have devices that can interfere, like microwaves, phones, etc.
Also, if its a newer express try using the 5GHz band and that the airport is set up to "Join the network" not "Extend".
Dec 25, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple® - AirPort Express Wireless-N Base Station
No. The airport express just has a shorter range. You can use both a regular base and express to extend the range further. Also, the express can be used at your home stereo. You can play your Itunes library directly to your stereo with an adapter to the express. Anyway, the express is just a less powerful wireless, with some special features. We print through it and use it exclusively. May add base station later. Good luck.
Jun 16, 2008 | Computers & Internet
Which wireless router.
if your using a imac product i would suggest for this complex system a cisco router they will have all you need in properties and allow streaming sound and video threw there routers
its a preference i like to use
little bit more money but the quality is what your looking for right
May 19, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Yamaha RX V800 w/ iTunes Airport Express
thats cause your patch cable is mono get a stereo 3 ring connector.
Apr 01, 2008 | Yamaha RX-V800 Receiver
New wireless network - now my airport express and airtunes does not work
Hi I was searching this site for a solution to a problem I am having and came across your post. I had the same issue and what I did was reset my airport express to factory settings (detailed in manual) - this enabled the Airport extreme to find/pair with it.
Sep 02, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple AirPort Express (M9470Z/A) 802.11g/b (M9470ZA) Wireless Access Point Logo
218 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
