Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice maker will not eject ice cubes in GE Profile gss25tswass
Cubes are frozen in maker, willl not eject into bin.
  • mcurb Mar 31, 2009
    I have an LG but the same problem. Ice is frozen in the cube maker and the cubes will not eject. I have turned the ice maker off and it will not thaw/melt. How do I get thes frozen cubes out?
Empty all ice from the bin and from the "Drill" like Ice shaper spinning unit. Let the unit make some new ice and see if that works.
Posted on Feb 14, 2009
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Dumping ice
If heater element is open the newly made cubes will stick to the tray and not be pushed out by the fingers doing the ejecting.
Apr 08, 2014 | Whirlpool 2198597 Ice Maker
The Side by Side GE Profile refrigerator does not dispense any water or ice. It worked for a short period of time but just stopped working. Also, all the options that are suppose to be lite go off when the...
Could be several problems (I'm a homeowner, not an expert). GE had a problem with the water line in the freezer door: not enuf insulation so the line freezes, hence no water flow. I would look at this first, especially if you press the water dispenser handle and you hear the pump, but no water comes out. Ditto if the ice bin is empty or the ice maker isn't making any more ice. If the icemaker is making ice but not dispensing it, then the auger (thing that agitates the ice cubes in the bin) may be broken or frozen. (if frozen be sure ice cubes in bin are loose and not frozen into one big ice cube).
Aug 13, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
My GE Profile refrig ice maker makes hollow ice cubes. Why would this happen?
Not enough water is being pumped into the icemaker. The water pressure in the water line coming into the refrigerator may be too low, perhaps due to a blockage somewhere.
Move the refrigerator enough to get behind it. Turn off the water at the small valve which connects the water line from the house plumbing to the tube going into the refrigerator. Get a bucket. Remove the refrigerator water line from the on-off valve (there should be a compresson nut holding it on). Point the incoming water line into the bucket and open the valve. Do you have a good flow of water? If so, either there is a blockage in the tubing within the refrigerator or the water valve at the bottom of the back of the refrigerator is malfunctioning.
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
I have a GE Profile Side by side that is working fine except the ice maker won't dump the frozen ice cubes in the tray. Another party in the house decided it would be a good idea to put water in the tray...
The ice maker is basically frozen. There are two fixes for this condition. If you can transfer all of the food out to another appliance you can unplug and open the doors and let it completely defrost on its own.
the other method is to use a blow dryer. When you have completely defrosted the ice maker and thoroughly dryed it spray the ice cube tray with pam cooking spray which will act as a lubricant. When you are ready to make ice again expect the ice maker to take about 24 hours before the first batch of ice cubes are ejected.
Jun 16, 2009 | GE Profile PSS26NGS Side by Side...
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice cubes are frozen but will not eject into the ice bin. I need to know how to get them out.
HI, You can use a hair dryer to the bottom side of the ice maker and it will let the cylce finish and remove the cubes. Can you tell if the cycle has started?
Please let me know if I can assist you further.
Thanks
Vic
May 18, 2009 | Maytag MSD2454G Side by Side Refrigerator
My GE Profile makes ice but then the ice cubes melt!
repl main board and make sure your out let is properly wired and grounded those main boards are sensitive when not grounded
Oct 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
468 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
