Question about HP LaserJet 8150dn Printer
HP 8150 prints OK for 30 minutes then will not go.
The printer display shows ''processing Job'' then ''receiving Data'' then does nothing.  Next day, prints OK for about 30 minutes. I print music parts from Finale, two pages up on 11x17 paper. Looks great when working.
  • 1 more comment
  • BigBandScore Mar 12, 2009
    My printer had a 600n jetdirect card.  I opened up the printer by the power supplies, cleaned out the dust from the fans and elsewhere.  I also replaced the 600n with a new 620n.  I have not had the problem since that.  I printed an event log but it didn't go that far back in time to show the original problem.  I think I am all set. The only problem left is that input tray one grabs more than one sheet of paper, so I have to hang on to the lower sheets and feed the next sheet by hand.  I have read some reports about a pad at the input but can't see it.  I am printing on 32 pound paper if that has anything to do with it.
  • BigBandScore Mar 13, 2009
    I will have to find a source and buy the separation pad before I ask for help.  I have the service manual on PDF and will look for instructions there.  Do you know of a good source or should I buy it from HP?
  • tonersmart May 11, 2010
    is this a networked printer with a "jet direct" communications card on it?
    Go to INFORMATION MENU. Hit ITEM till it says PRINT EVENT LOG then hit SELECT. Let me know what it says. With your input we can figure it out.
  • 34 Answers
I am certain you need to replace the tray one seperation pad. That will solve your problem.
I could walk you through it if you like. Very easy to do. Sep pad costs around $10 but it can be installed in two minutes. Easy.
Posted on Mar 12, 2009
  • tonersmart Mar 13, 2009
    I havent been on here too long, so dont know if the following is OK with this site. I fix HP printers for a living, have all parts in stock. My company's name is Tonersmart, HP laser printers are all we do, we remanufacture HP toner cartridges and have been in business in central Florida for 17 years.
    I can put a sep pad in an envelope and send if you wish. It is a tiny part. Then you can just call me and this job will only take a minute. Just to be clear, the sep pad WILL STOP what is called "multi-feeding"....picking up more than one sheet of paper at a time. No tools are required for this job. You will not even need instructions to do this.
    Many people do not know that working on HP LaserJet printers, for the most part, is very easy to do. email: tsmart@gate.net
I'm getting the following message on my HP Photosmart C6180. Ink system has failed. Unable to copy, receive faxes, or print. Error: 0xc18a0201
Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release the "OK" button
1. Press and release the right arrow button until the display says "System Configuration Menu".
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
NOTE: If the error is still there, or reoccurs replace the unit.
Aug 23, 2011 | HP Photosmart C6180 All-In-One InkJet...
My hp printer m1005 show error 20 and some time error 17. Plz. give me solution.
A 20 error is insufficient memory.
The device received more data than can fit
in the available memory. You might have
tried to transfer too many macros, soft
fonts, or complex graphics.
Touch OK to print the transferred data
(some data might be lost), and then simplify
the print job or install additional memory.
As for the 17 error?...I can't find it in the manual.
Feb 13, 2011 | HP LaserJet M1005 Printer
Receiving error message: 0xc18a0001 error message on hp c8180 all-in-one printer. what can I do?
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If I've helped you, please vote! Thanks!
Dec 09, 2010 | HP Photosmart C8180 All-in-One InkJet...
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
Paper jam warning. I cannot find any paper in
Please try to turn off your printer and unplug all the connection in the printer from its power down to its usb or parrallel connection. And let it up to 30 minutes to unplug and turn off. This process is letting your printer reset it self and loading its default and original settings. Usually it loads it original settings. After 30 minutes please plug all the connection of the printer and then turn the printer on and test the printer by printing a document or any files you want to print. Please observe what is the result.
Thanks
Aug 07, 2009 | HP Photosmart 8150 InkJet Printer
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
My HP deskjet F4810 printer keeps going offline
hi dear
this link for your driver
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-40457-1&lc=en&cc=us&dlc=en&product=1128296&os=228
oke....
post in me back
thks
ropp
Mar 12, 2008 | HP DeskJet F380 All-In-One Printer
HP LaserJet 8150dn Printer Logo
194 people viewed this question
Ben Johnson
