Question about Sharp AL 1631 Copier
Loud clicking noice during copying
Recently purchased copier. After a week the unit is now making a 'rat-a-tat-a-tat' noise while making copies. The copies/paper seems to come out fine without jamming. Is this something / known issue that we can fix?
    Problem Solver:
  • 5 Answers
Take the toner unit out check toner recovery bottle on the front of toner unit, empty or vacum it out dale, if not that could be gears on the machine drive, or fuser, or down in the by-pass dale
Posted on Feb 14, 2009
There seems to be a grinding noice coming from the bottom of the copier. It will feed paper from either source, the tray or the manual feed, and then the copy gets caught and shuts down the copier and you...
Diagnosing noises over the internet is an impossible task unless it is a known problem on a particular model. usually grind noises are casued by something trying to turn something that wont. It maybe something as simple as a siezed drum. As you have not stated what model of copier you have, i am sorry but i cannot proceed any further.
Jul 24, 2011 | Canon Office Equipment & Supplies
My printer wont print. I have recently upgraded to windows 7. have downloaded the new driver. but it wont print. i have tried a full reset, partial reset, taking out ink and restarting, putting ink back...
You need to check the hardware functionality of printer first. Make a copy from printer and check if it prints fine. If hardware is okay. You can try following steps on computer.
1- On computer keyboard press Windows(flag) button and R at the same time
2- This will open a small Run window
3- Type devmgmt.msc in Run window and click OK
4- This will open Device Manager window.
5- Right click on psc 2410(2400) entry under "universal serial bus controller" and 'imaging device' and click delete/uninstall/remove. Printer's entry should disappear from there.
6- Disconnect usb cable from printer and computer
7- Wait for 50 seconds.
8- Connect the usb cable to printer and computer.
9- This should install the drivers automatically.
Dec 23, 2010 | HP PSC 2410 All-In-One InkJet Printer
Copier making loud noise
Remove the drum/toner unit and close the top,...does it still make the noise? If so, there is a paper jam in the fuser section (left side)
I also have a Canon PC900 series copier....mine does not have the automatic document feeder, however the machine is the same....If the noise persists, you will probably need to replace the Fixing (fuser) Unit drive gears (worst case senerio) perhaps you can locate the jam in the fuser and "carefully" remove without damaging the Fixing Belt....good luck
Jul 02, 2009 | Canon Office Equipment & Supplies
Machine makes a loud wheezing noise just before
Mite have a broken gear in the fusing section (Hot Part) unplug machine and open **** shell and look to the left (if standing in front of machine) the left side rear is the fusing drive section check all gears also remove image unit and check gears
May 02, 2009 | Minolta Office Equipment & Supplies
Canon imagerunner 1310 loud noise
Hello sir; I suggest reinstall drum unit again ,you will find out what's going on.
Apr 28, 2009 | Canon ImageRUNNER 1670F Copier
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
Loud clattering noise
-Open the Front Cover. -Remove the Toner Cartridge -Remove the Drum Cartridge -Next locate the black gear attached to the end of the Drum and turn it with your fingers. -Check to see if the gear is locked, or difficult to turn. The gear will only turn in one direction. -If the gear won't turn at all, or if it catches while you are turning it, or if you hear the same noise when you turn the gear that you heard when the machine was on, the Drum Cartridge is the cause and will need to be replaced.
Jun 22, 2007 | Xerox WorkCentre XE88 Laser Printer
Sharp AL 1631 Copier Logo
124 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
