Question about OKI C7200 Led Printer
Phaser 7300 - refilling toner?
Can anyone recommend a source for high quality toner for phaser and oki printers that is as close to the genuine toners as possible?
I tried some ebay toner many years ago and it was too coarse for my drums and the quality wasn't as good as original (more matte, dull colors, no shine). I am thinking that there are probably better choices these days.
I have 4 colors toner for my last Oki C7200 they are so good (as good as genuine) and I have used them for many years till my printer gone. however please email me if you want them to
Posted on Nov 23, 2009
Jam at exit open door a
Could be a fuser problem, but could also be very poor quality toner cartridge(s). If a remanufacturer/compatible maker uses the wrong toner powder, it can have the wrong characteristics.
I've seen these printers with poor quality cartridges able to print a page with very little toner coverage OK, but jam EVERY page that has much real 'density' of toner. Even the configuration page on these printers has a solid band of red 5mm or so wide across the lower part of the page. Poor toners - where the fusing temperature is incorrect for this printer will cause the page to jam in the same place in the fuser EVERY TIME.
The cure - Genuine Xerox toners, or GOOD QUALITY remanufactured toners from a reputable source.
Aug 19, 2014 | Xerox Phaser 6180 MFP/D laser toner
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
My phaser 6180 color printer, toner not adhering to paper could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
High. I have just bought a Xerox Phaser 7300 Laser Printer and don´t fancy paying top end for the Toner. Does anyone know if I can refill/reset the cartridges? Thanks for any help.
you can refill the cartridges without having to reset anything. Many companies on the internet sell bottles of toner which are alot cheaper (eg uninet), you can also make override the imaging units by going into service diagnosistisc
May 20, 2010 | Xerox Phaser 7300DN Laser Printer
I have refilled the xerox phaser toner it is asking for toner card
Is there any chip identifier for that toner. If there you have to change the chip. Otherwise yiu refilled wrong toner posder for that toner.
Oct 18, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Can Xerox Phaser 6280 be refilled by Consumers?
The 6280 uses a specially designed toner called Emulsion Aggregation toner. This is a special type of toner made by Xerox. Sice it is so new and patents exist, I doubt that anyone can legally make the toner, even if they posessed the equipment and the expertis. Refilling with non-EA toner is asking for big trouble.
Aug 12, 2009 | Xerox Phaser 8200 Laser Printer
Need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Aug 08, 2009 | Xerox Phaser 3100MFP/S Laser Printer
How to refill xerox phaser 6125?
Just found a supplier for toner and reset chips for my new 6125. Don't know where you're based but in the UK you can use the following link:-
In the US, a possible source from EBAY is:-|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
Good luck.
Apr 07, 2009 | Xerox Phaser 6125 Laser Printer
Xerox Phaser 7300
CHECK YOUR toner cartridge may it is leakaging of ink powder.also check your asebly clear the dust.some times roller also has problem but most of the problem of toner cartidge change it then try.
Sep 30, 2008 | OKI C9300 Led Printer
OKI C7200 Led Printer Logo
76 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
