Question about Kenmore 24032\24036 Top Load Washer
Washer making rubing noise while turning
Good day people,
I have a Kenmore Elite washing machine, model number is 22952. It is a top load machine. We have had it about 5 years. As if yesterday and time the washer starts to spin, be it for agitating or spinning it is making a rubbing noise. Kind of like a belt rubbing against something. I have change my ratcheting "dogs" already on this beast but I cannot figure out how to get into this machine or what it could be. Everything I have read so far is these machines are direct drive (not sure about this one) any help would be greatly welcomed.
Kemp
  • 8 more comments
  • kemp_larson Feb 14, 2009
    I have been back there, I saw about 4 screws, but I have several plastic clisp and the water drain is holding the panel back. I am afraid if I pull that off I wont be able to get it back on.. I can send pictures too
    Sorry I didnt mention that. I did remove the hose. The hose has a plastic plate that it connects to. This plate has very little play in it. I can pull it out a little bit and I can see the hose inside that the plate connects to. Maybe I could turn the plate, to get it through the hole. I was just nervous at this part. and stopped and came here for some good advice. :)
    ok, got the back off, not sure if I can put it back,lol. Ok now what do I look for on the gear,clutch brake? They all look pretty good and clean.
  • kemp_larson Feb 15, 2009
    Ok, i got it spinning and everything looks normal as far as I know. The basket spins balanced. The drain shot out some water to wake me up nicely though.
    The sound is like a belt rubbing against something, but I know there is no belt in there tho. Any ideas?
    I believe so, it is on the bottom of the basket and on top of what looks like an iron transfer case of some sort
    Nothing bent, there is what appears to be some metal shavings below this, but very very little. There is an slight oily patch where the machine was in about the same area this . At first look I was thinking it was detergent that had spilled.
  • kemp_larson Feb 16, 2009
    Is this an easy fix? Hopefully. You will love this, my wife needed to do laundry, so I put it all back to gether again......well I forgot to put the drain back in, what a flood that made...lol......she didnt laughthough
    Thanx for all your help. Would it be ok to wait untill it goes,or should I fix it before it makes more damage?
    Yes it does, thank you for all your help!
    President:
  • 1,902 Answers
On the back of your machine you can remove the back panel think it is about 8 screws. Once you get the back panel off look closely at the motor. Motor mounts, gears, clutch, brake, and if need be take the bottom apart and look at the main bearing on the bottom of the drum to make sure that hasnt gone bad
Posted on Feb 14, 2009
  • 8 more comments
  • Jeremy Reddick
    Jeremy Reddick Feb 14, 2009
    Remove the drain hose. It just slips off and on very easy
  • Jeremy Reddick
    Yes the plate turns and that is how you get it off
  • Jeremy Reddick
    Trun the machine to spin cycle and see what happens in the back like what wobles and what is steady. Then go from there on what to replace
  • Jeremy Reddick
    Jeremy Reddick Feb 15, 2009
    So you got a bath? Sorry. Well I am glad everything is setup and working proprly. Sometimees on washing machines they stay off balance for a little bit until the system comes around to the changes
  • Jeremy Reddick
    Can you see a brake or the clutch spring?
  • Jeremy Reddick
    Yes exactly. Does that look oily or any thing look out of the ordinary. meaning does it look like there is any type of rubbing or anything bent
  • Jeremy Reddick
    Jeremy Reddick Feb 16, 2009
    Seems like you are losing your main bearing. That would make a loud noise and if you see metal shavings and things like oil it is all signs.
  • Jeremy Reddick
    LOL, that is funnym at the same time it isnt. To answer your questtion no this is not to easy of a fix. You literally need to remove EVERYTHING from the bottom of the washing machine. The belt, motor, pulley, clutch, tub outer, and then get to the bearing then realase the bearing and get it back in. Very easy to take apart paint to put back otgether
  • Jeremy Reddick
    With the details I have recieved from about the metal shavings I am kind of pulled both ways. To a point I say that it would replace the bearing, but to the other point I would say that just wait for it to go out. I am only worried that if the bearing is rubbing on the bearing race that the cost to replace will be more expensive then just repairing now. If you let it ride then you are going to have to deal with the noise so. I hope that this helps
  • Jeremy Reddick
    Jeremy Reddick Feb 17, 2009
    You are welcome and make sure the drain line is hooked up lol have a great week
Kenmore elite oasis washer makes noise and unbalanced
If your washer start going to high speed and it make unbalance and bangin on the frame. there was a stator may need replace....good luck
Nov 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite top filling washer 22952 100 spins as its filling with water and makes a loud grinding noise as it changes cycles
chances are there is a piece of broken glass in the bottom. Happened to me , found out a glass had broken and pieces were causing a grinding noise.
Jan 29, 2011 | Kenmore Washing Machines
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
Need age of my washer machine
Kenmore elite model number 22054100 serial number CL210158. How old is this washer?
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Where do I Find the model number on my Kenmore Elite Top load washer?
The model number on Kenmore top loaders is usually printed on a nameplate along the wash tub rim opening under the washer lid. The model number has 8 digits with a prefix of "110". If you cannot locate it, please let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 24032\24036 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore washer elite top load
sounds like you have a bad coupler.mach does not have a belt it uses a coupling system between the motor and trans.if you fill mach and it makes the same noise in agitation,replace the coupler
Sep 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore elite calyspo washing machine model #110.2206
that washer the noise you are saying i have found maney things the most common one being the break and basket drive
Feb 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
229 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
