Question about Indesit W 123 Front Load Washer
Indesit washer wil 103
During the wash cycle the water boiled up had to stop washer when switched back on the door light flashes plus 2 green lights 3 and 4 washer will not run properly now to turn off have to turn off at mains any suggestions Thanks Ladram
    President:
  • 1,902 Answers
Check your water inlet valves. Seems like the valves have went away. Also check the computer board and inline fuse to make sure everything is correct. Inlet valve are located behind the supply line hoses. Please rate. Thank you
Posted on Feb 14, 2009
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Iwde12 indesit, not selecting programmes not releasing water, not drying
Hi, I have an indesit IWDE12, I programme the washer which then starts to spin with no water, after 2-3 mins the rinse light, the clock light and the door lock light start to flash and tha washing stops. Does anyone know what this problem could be?
Jun 15, 2010 | Indesit W 123 Front Load Washer
Indesit wil 103 door won't open...
Welcome to Fixya.
Try holding the Start/cancel button in for at least 2 seconds.
If there is another lamp flashing at the same time as the door lamp, then you will have to call an engineer.
Dec 18, 2008 | Indesit W 123 Front Load Washer
We have a indesit wil 143s faulty
the pressure switch should be easy to replace. it will be a round unit with wires going into it and also a small clear plastic tube attached. it is usually mounted around the top edge of the case. i would also check that the pressure system is not blocked (the other end of that clear plastic tube) as blockages may keep pressure at the switch leaving it in the "full position" pop the pressure tube off of the switch and force some air down the tube to check.tony.
Jun 03, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
118 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
