Washer motor locks out and won't aggitate or spin
There seems to be a small green light on the circuit board blinking 7 times. Diagnostic? I don't know this is the second replacement motor. Please Help I can't get any info from G. E.
    President:
  • 1,902 Answers
7 blinks is a lock out code for water supply error. Here is what you can check. Please rate if I helped you.
No frequency change for 60 minutes from water supply. Press POWER button. No other buttons work:
· Check wiring harness
· Check water valve· Check pressure sensor switch
· Check circuit board
Posted on Feb 14, 2009
My ge washer model wjsr4160g1ww will not spin or aggitate
A lot of times when that type GE Hydrowave washer does not spin/agitate it can simply be resolved by resetting the motor control board. This tip i wrote explains how to reset the motor inverter board and see if that resolves the problem with the washer. http://www1.fixya.com/support/r10292912-will_ge_hotpiont_top_load_washer_not
If ya try restting it and it does not work watch at the little green light on that motor board and see how many times in a row it blinks and reply with that number of times it flashes and i will tell ya what error code is being displayed
GENE
Oct 23, 2011 | Washing Machines
I have a WFMC5801UC Bosch washer It will fill and it will drain the door locks and unlocks but the drum will not spin and the belt is not broken every thing seems fine but it just won't move anymore
Check all socket plugs on all harnesses, motor, printed circuit cards, after unpluging unit. Are there any flashing lights on the circuit boards.
Sep 01, 2011 | Washing Machines
Will not spin or agitate
Remove the front panel. Observe the motor flashes.
The motor blinks on and off all the time.
It blinks faster when running.
If a failure occurs you will get the following flashes:
1 flash bad motor
2 flashes slipping belt
3 flashes corrupted software bad motor
4 flashes failed mode shift circuit
5 flashes bad motor
6 flashes locked motor check for objects between tub
7 flashes bad lid switch.
8 flashes motor overheated too much soap
9 flashes brake resister is toast bad motor.
To Reset the Inverter Board: Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes. If no light is visible you have a blown fuse built into the neutral side of the harness on the white/red wire.
themobilian_2813.jpgthemobilian_31.pngIf you see a small bubble in this black heat seal and the motor light is not on then the fuse within is blown replacement part is WH49X10041
What else do I have? Oh yeah how about the SERVICE MANUAL
Aug 12, 2011 | GE Profile WPRE6100G Top Load Washer
Washer will not spin or ajatate. I need to remove the front panel to see what up?
Use downwards force to relieve tension on the spring clips holding that front panel on.themobilian_1904.jpg
Video how to:
Once yall have the front panel removed yall will notice the motor has a green blinking light on it.
The motor blinks on and off all the time It blinks faster when running. That is normalment mon ami.
If it ain't acting right it will display flashes:
1 flash bad motor
5 flashes little green men (bad motor)
7 flashes bad lidswitch.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.themobilian_26.pngthemobilian_27.png
Service manual and more HERE
Mar 16, 2011 | GE Profile WPRE6150KWT Colossal Capacity...
Hi, I overloaded my washer with towels. It hasn't fully drained (can hear water beneath the tub when you move it). I tried unplugging it for a minute, but the same problem presents itself. When start is...
The motor has a power inverter on top of it. Try and reset the motor by doing this:
Turn the washer off. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. It may take a few times. The motor has a green light on it that blinks. If it ain't acting right it will display flashes:
1 flash bad motor
5 flashes little green men bad motor
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.themobilian_4.png If you see a liitle bubble in there then you know that dude is toast.
That fuse is: $7.50
Nov 29, 2010 | GE Profile WPRE6150KWT Colossal Capacity...
GE top loading washing machine drains and fills but does not agitate or spin. Wiring around lid switch resolved problem for one load only. Flashing green light on motor circuit board seven flashed each...
7 blinks DOES indicate a problem with the lid switch.
Replace the switch, and inspect the wiring for cracks/wear.
Can you hear the motor spinning?
Is there black plastic chunks under the washer?
What is the model #?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 25, 2010 | GE Washing Machines
Washer fills and drains but won't aggitate or spin
Seven flashes means the washer did not sense a lid opening. Check the lid switch.
May 30, 2009 | General Electric WJRR4170GWW Top Load...
Washer will not spin or aggitate
1. unplug for ten minutes.
2. plug back in.
3. open/close lid 5 times.
4. wash clothes!
Sep 18, 2007 | GE WWSE5240G
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
